Closed Thread
Old 05-03-2013, 08:09 PM   #5411
Originally Posted by B47 View Post
Let's just say it is a good aeronautical practice. It is in some FAA Advisory Circulars.
Think about it - what good does a self locking nut do if not all its threads are engaged?
In this application, just to keep it from falling off.
OldCoot is offline
Old 05-03-2013, 08:10 PM   #5412
TURBS's Avatar
Originally Posted by OldCoot View Post
The locking nut in this application is not torqued but just screwed on enough to bottom the bolt and washer against the bracket sides. It is just a pivot for the pole.
Pole pivots on bushing so infact the nut does get locked tight and torqued.
TURBS is offline
Old 05-03-2013, 08:12 PM   #5413
B47
In your two bottom photos it looks like the nut is simply hand tightened and it doesn't look like the bolt and washer are bottomed out. I thought at first look that you had just "dry fitted" it together.
B47 is offline
Old 05-03-2013, 08:13 PM   #5414
So if the pole does not pivot on the bushing, the bushing will turn in the bracket?
OldCoot is offline
Old 05-03-2013, 08:15 PM   #5415
B47
Come on - show me at least two threads showing on the bolt.
B47 is offline
Old 05-03-2013, 08:18 PM   #5416
TURBS's Avatar
It is just mocked up to test fit.
Paint is next.
TURBS is offline
Old 05-03-2013, 08:20 PM   #5417
TURBS's Avatar
Bushing goes all the way through pole not just on outsides.
Make sense?
I can take it apart and show you if your not clear.
TURBS is offline
Old 05-03-2013, 08:24 PM   #5418
B47
Exactly - so torque the nut enought so all of its threads are engaged and it won't fall off.
B47 is offline
Old 05-03-2013, 08:28 PM   #5419
Make sense?
So does the bushing bottom on the insides of the bracket or go thru the bracket legs also?
OldCoot is offline
Old 05-03-2013, 08:40 PM   #5420
TURBS's Avatar
Bottom on bracket sides.
TURBS is offline
Closed Thread
