Closed Thread
Old 05-04-2013, 07:19 PM   #5471
PPST OGCDG
Frank-VA's Avatar
Originally Posted by mackman1994 View Post
Best way to fix a GM is remove the radiater cap and drive a Ford under it!!
I second that
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline
Old 05-04-2013, 07:23 PM   #5472
B, question: Do you safety wire nuts/bolts on your camper according to AC 43.13-1B sect 7-123 & 124?
OldCoot is online now
Old 05-04-2013, 07:26 PM   #5473
Originally Posted by Frank-VA View Post
I second that
But according to Turbs, you're senile so it you don't count and as for mackman, he just doesn't know any better.
Old 05-04-2013, 07:34 PM   #5474
Originally Posted by B47 View Post
I want to see if the lock nut was properly torqued - remember what the ac says.
Need pics
Turbs, when did you start working on airplanes?
Old 05-04-2013, 07:37 PM   #5475
TURBS's Avatar
Yesterday .........
TURBS is offline
Old 05-04-2013, 07:38 PM   #5476
B47
No but if the factory did sw, I would certainly have to redo some if not all of it
I always enjoyed sw and was good at it. I learned it right the first time in the active duty af.
When I was a Air Reserve Technican at Carswell AFB if your sw wasn't by the book the inspector went snip snip
We used mostly .032 SS wire, but some applications needed .064.
Saw a lot of sw while I was a FAA inspector that I didn't like, but as long as it was pulling in the right direction there wasn't much I could say.
B47 is offline
Old 05-04-2013, 07:41 PM   #5477
B47
Come on OC - it doesn't matter if its an airplane or an awning pole, just do it right.
B47 is offline
Old 05-04-2013, 07:43 PM   #5478
We safety wired critical items on our race cars also and still have the mil spec 0.032 wire and 2 sets of pliers. Drain plug was one of the critical items.
Old 05-04-2013, 07:43 PM   #5479
TURBS's Avatar
TURBS is offline
Old 05-04-2013, 07:46 PM   #5480
B47
Originally Posted by f1100turbo View Post
OK - just don't change it after the pic and do the same with the others.
B47 is offline
Closed Thread
