07-24-2013, 07:57 AM
#11361
Phat Phrog
It is amazingly beautiful on The Farm here in Mid Missouri too! Hi only 80 and tonight 56!!! So happy to have the air off finally!
Kenny n Karen
TV: 2017 Chevy Silverado 3500 LTZ - named Betty
RV: 2017 Columbus 366RL - named Karen’s Camper
07-24-2013, 08:13 AM
#11362
Originally Posted by OldCoot
Fri. unless we have trouble. When can we expect your ugly mug?
Top secret. ...
07-24-2013, 08:16 AM
#11363
Phat Phrog Phlunky
same in SE WI.
Figure I'll ask here rather than the FROG thread, I need to be out of town 8-5 thru 8-7. I'm working to convince the Chick, (mine, not RVChick ) that we should head to Goshen on 8-8 to see all the Phat Phrogs.
If I get the nod, I'll see if there are any public sites available at the fairground, if not, anyone know of any private CG's close by?
Scot, I am "that guy"
2014 Raptor 27FS
2014 Ram 1500 Laramie
Days camped in 2013 = 30 final.
Days camped in 2014 = 27 final.
igkra.com
07-24-2013, 02:13 PM
#11364
Phat Phrog Phlunky
Wow that was a thread killer!
Found out they have sites available for us if we can do it
I'll let uall know if it's gonna happen.
2014 Raptor 27FS
igkra.com
07-24-2013, 02:23 PM
#11365
Looking forward to seein ya !
Hope it werks out!
07-24-2013, 03:48 PM
#11366
Do not worry about the old coot, he will be traveling with us, I been loading tools for day's incase he has a problem. Looking forward to this adventure.......
Coachmen M/H
Concord
2018 / 300 DSC
07-24-2013, 03:55 PM
#11367
Afternoon phrogs !
Picked up the W&P from dealer today. Frig problem was a bad fuse link wire. They lifted the trailer, just used the lower bracket holes, n ground any remaining panel material away.replaced the sprayer handle at kitchen sink. And added some curvature to the finder ? I pointed it out to service rep, and he offered a free wash.....in about 1 1/2 hrs. Because he only had one guy today at wash station ? Hummm...
07-24-2013, 04:29 PM
#11368
Phat Phrog
Yippee!!
Kenny n Karen
07-24-2013, 04:32 PM
#11369
Phat Phrog
Busy you are RB!!
Kenny n Karen
07-24-2013, 04:34 PM
#11370
Originally Posted by Rolling buckeye
Afternoon phrogs !
Strongly suggest you get a wet bolt kit for the suspension.
07-24-2013, 04:37 PM
#11371
Looking it up next! Ya I didn't like all the rust,thought humm,need to do something about that ! This I did not think oph ! Thanks OC !
07-24-2013, 04:42 PM
#11372
Learned that the hard way! Make my own now, just grind a small flat on the bolt shank, cross drill a small hole in the center and drill a hole in the head of the bolt to the center cross drilled hole and thread it for a fitting.
07-24-2013, 04:57 PM
#11373
Ok OC This will be at the top o my list. But not something I can do right away. So for now, scuff with sand paper,spray off with break clean,lithium grease at bolt, Then maybe a shot of blk paint,at old bolt holes ?
07-24-2013, 05:06 PM
#11374
One my flagstaff
I'm a cheap a#@ I just took my bolts out and drilled them and added grease zerks.
Total cost $5.00
07-24-2013, 05:18 PM
#11375
Iph I get new bolts, to practice or may be drill n install zerks,then install. Would t get g 8 in matching size or more ? Hole before tapping to zerk thread, bout 1/16 "? Only in end ways, 1/2" - 3/4", then connect hole from side 1/16 also ?
07-24-2013, 05:22 PM
#11376
I used tap in grease zerks so I didn't have to tap holes.
Whatever size drill that was required for tap in zerks I used to cross drill bolts.
I connected cross drill and side drill but not all the way through.
Maybe 8 minutes per bolt till I got it down pat then a couple minutes to drill and hammer in zerk.
07-24-2013, 05:47 PM
#11377
Ok cool, but what grade bolts are they. ? N this is a dumb question but,which end ? Head right ?
07-24-2013, 06:20 PM
#11378
Mine were grade 5.
Correct I Drilled from bolt head end.
By the way I used the original bolts as there was nothing wrong with them.
07-24-2013, 06:24 PM
#11379
Excellent ! Thanks !
07-24-2013, 06:36 PM
#11380
Phat Phrog
Ok girl talk time.....I'm just sayin.....
So Turbs.....I am going to fix your onion bombs this Friday night at our family float! There are several in the Phamily that love to cook....so I am gonna impress em with a phellow Phrog treat!
Kenny n Karen
