10-25-2013, 07:26 AM
#14521
Phat Phrog
Originally Posted by SYE
I have to ask, what is the pepsi bottle for, the Blue Streak??
I was wondering that too Sy!
Kenny n Karen
TV: 2017 Chevy Silverado 3500 LTZ - named Betty
RV: 2017 Columbus 366RL - named Karen’s Camper
10-25-2013, 07:29 AM
#14522
Phat Phrog
Originally Posted by AquaMan
Blew my lines when we got back from weekend campout last Sunday. Still need to pump the juice through. Got the roof washed and treated. Suppose to be a little warmer this weekend, may try to wax front cap. DW is doing final cleanout today, and packing what we can for early spring trip to FL.
Hey Chicky, have gone through the "it's too big/not big enough" stage yet? Every construction project, or house, we've done, has had it's stages from foundation (too small), framing (maybe too big), under roof (I feel closed in), wallboard (seems big again), move in --- Just Right!
Well then.....I think I am right on track with all those feelings!!
Kenny n Karen
10-25-2013, 07:30 AM
#14523
Phat Phrog
Originally Posted by f1100turbo
Nice house chicky !
To bad ole turbs isn't setting trusses!
I know!! They are setting the second truss now!
Kenny n Karen
10-25-2013, 07:31 AM
#14524
Phat Phrog Phlunky
The house is looking great Chick
how much pink do you guys throw in the drains? I blew everything out a couple weeks ago but I only used 1 gallon of pink on the drains...........
Scot, I am "that guy"
2014 Raptor 27FS
2014 Ram 1500 Laramie
Days camped in 2013 = 30 final.
Days camped in 2014 = 27 final.
igkra.com
10-25-2013, 07:32 AM
#14525
Phat Phrog
Thanks Essness!
Kenny n Karen
10-25-2013, 07:33 AM
#14526
Phat Phrog
This is looking out the rig window...
Kenny n Karen
10-25-2013, 07:37 AM
#14527
I run mine thru the whole system....
Its what I do.
10-25-2013, 07:47 AM
#14528
I have 4 traps and use about a 1/2-2/3 a gallon for them. I keep my system dry for the winter because the DW does not want that stuff in her water lines.
I do put about a 1/2 a cup on top of the rubber seals in the thrones.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
10-25-2013, 07:48 AM
#14529
Thats awesome RVC!! What fun.
Shane & Antoinette
10-25-2013, 07:54 AM
#14530
Maybe I can come visit your shop since I'm not allowed in nc anymore......
Not until I put in a (Metal Detector)! Youroo!!
10-25-2013, 07:58 AM
#14531
Phat Phrog Phlunky
Thanks Lynk, I leave mine dry as well. It's just easier than have her always question if I rinsed it enough when we return to service
2014 Raptor 27FS
igkra.com
10-25-2013, 08:00 AM
#14532
Shane & Antoinette
10-25-2013, 09:51 AM
#14533
PPST OGCDG
Its what I do.
I now Blowout the water lines and leave them dry. I only use the pink stuff in the traps
Turbo you to invest in this: Quick Turn By-Pass Kit - Camco 35983 - Winterizing - Camping World
I installed mine after W-L-A-T Brand Antifreeze messed up the Water
filter housing.
The new one is on the left
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
10-25-2013, 01:11 PM
#14534
The water bypass kit is (VERY) restrictive! Your F/W suction side of the pump travels thru this,also. The Pics show Dia.of hose from tank and the hole Dia.thru the Valve,noted by drill bit reference! Now you also must realize that the On/Off internal bore is (ONLY 1/2) of the in and out Bore. If you are happy with LOW volume supply in your R/V put one of these in your Suction supply Hose! Youroo!!
10-25-2013, 06:02 PM
#14535
Originally Posted by Frank-VA
Frank-VA is the one on the right for (White Lightning)? Youroo!!
10-25-2013, 07:02 PM
#14536
PPST OGCDG
Now That I do not put Antifreeze through the fresh water lines,I will probably remove the By-Pass.
I wonder if the valves could be drilled out with out messing up the valves?
By putting White Lightning in the fresh water lines I will not need to disinfect the lines in the spring with Clorox
Frank- VA {:-{)
10-25-2013, 08:50 PM
#14537
Disinfect?, you'd be lucky to have fresh water lines period! seriously though, you'd have people lined up ,in the spring, when you open the camper up wanting to "help"
10-25-2013, 09:22 PM
#14538
Phat Phrog
So here is how we looked yesterday
Here is today!
This is my favorite! This is looking from the east to the west, and the shape of the ceiling trusses! Should make the room look very spacious!
Kenny n Karen
#14539
Phat Phrog
Well that showed up backwards....Ha!
Kenny n Karen
10-25-2013, 09:28 PM
#14540
Looking good, should be under sheathing tomorrow!
