Old 08-29-2012, 09:21 AM   #21
handbuilder's Avatar
I have Nikon D200. I use 2 lenses -Nikkor AF-S DX zoom 18-135mn and a Nikkor 50mn AF
I also use a simple point a shoot Nikon S610 when I dont want to carry the larger camera. I will say the body of the D200 is beastly tough - its taken a drop with no damage...I got the gray hair thinking I destroyed my camera but glad to see it lived up to its rep.
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 08-29-2012, 10:09 AM   #22
Yukon Don's Avatar
OK, here's a question for you advanced guys (and gals).
These photos were all taken from the top of King Solomon's Dome just outside Dawson City. It doesn't matter which way you face, the view is the same.
If you look closely, there are mountain ranges in the distance. They are hard to distinguish from the clouds.
I shot these mid-afternoon, using the auto settings on the camera (something for which I am admittedly lazy).
Question: How would I make those distant mountains stand out to better effect ?
Would a polarizing filter help ? (I've never used one) Or would fiddling with my depth of field have made a difference ?
How would you guys improve these ?
ID:	18834   Click image for larger version
ID:	18835   Click image for larger version
ID:	18836   Click image for larger version
2009 Jeep Wrangler Unlimited
2012 Flagstaff T10RD
Yukon Don is offline   Reply With Quote
Old 08-29-2012, 10:36 AM   #23
chucker25's Avatar
Yukon Don - A polariser can certainly help in situations like these depending upon the angle of the sunlight vs where you are pointing the camera. POL filters work best when the sun is at right angles (off to your left or right) and have least effect when the sun is behind or in front of you. Haze (UV) filters may also help. Depth of Field isn't really an issue with this type of shot assuming you aren't focused on anything close to you. Large landscape shots with the subject far away tend to have plenty of DOF when your focus point is way out there. Remember DOF is controlled by your aperture setting. So if you were using f5.6 or smaller (f8, f11 etc) then DOF should be fine, especially when using a wide angle lens.
You can try 'bracketting' your exposures if you are able to - shoot one picture with the camera exposure, then one underexposed and then one over exposed. You may find the under exposed shot bring out the mountains in the distance a bit better, although the foreground may be a bit too dark.
Controlling contrast in these types of shots is the big task - you have relatively dark foregrounds (fields and close mountains) and relatively light far-grounds (clouds, sky, distant mountains). If you have the ability to use a 'graduated neutral density filter' it can really help bring the far-ground closer to the exposure of the foreground. Think of this filter as a pair of sunglasses that are only tinted on the top half. Darkens the sky but doesn't affect the foreground. This is often the best way to handle landscapes with bright skies.
Hopefully this helps.
2013 Rockwood A128S
Ford Ranger
chucker25 is offline   Reply With Quote
Old 08-29-2012, 10:42 AM   #24
Yukon Don's Avatar
Thanks, Randy -it does.
I intend to be back on top of that mountain next year.
Old 08-29-2012, 11:12 AM   #25
chucker25's Avatar
I should also mention - anytime you put any filter in front of the lens it can impact image quality. Filters, like everything else come in different qualities - the better filters use better 'glass', less distortion etc. Filters can also increase the likely hood of 'flare' or 'ghosts' in your image when the sun hits the filter directly. Use of a 'lens hood' or shading the front of your lens with your hand or hat helps a lot in this regard (just be careful you don't end up with hands & hats in all your images).
Also, a POL filter is very difficult to use if you do not have a way to look at the scene before taking the image as the filter needs to be rotated to get the effect desired. For DSLR's this isn't an issue and for most point and shoot digital cameras it isn't either as the display screen on back shows what is coming thru the lens. Just keep in mind that they do need to be rotated into the correct position.
I don't use a lot of filters, however I always carry a good quality POL and one of the graduated ND filters I mentioned.
TIP - buy a good quality POL that is sized for your largest lens, then buy inexpensive step rings so the POL can be used on lenses with smaller front threads. Saves you buying more than one POL, allowing you to buy a better one. A good POL is expensive so being able to use it on all your lenses helps lessen the pain. Most of my lenses are either 77mm or 52mm threads - so I have a 77mm POL and a 77/52mm step ring. I also have a 52mm POL, but when I want to carry minimal kit it helps to only have to lug one filter.
2013 Rockwood A128S
Ford Ranger
Old 08-29-2012, 11:58 AM   #26
chucker25's Avatar
Yukon Don - I looked over the images again. Another suggestion, from a compositional perspective, might be to zoom in more on the distant mountains if that is indeed what you want to emphasis. It is a similar scenario to a late evening shot that has a nice big full moon in the image. We want to include as much of the landscape as we can (wide angle shot) however when we do this the moon which looked so big to us in real life ends up being a small dot in the image. By using a longer focal length lens (or zooming in) we can keep the moon nice and large in the frame (albeit at the sacrifice of the broad landscape). These mountain shots are pretty much the same. Try a mix of both - some wide angle shots that provide context to the overall scene and then some zoomed in shots that embrace those distant mountains, bringing them in much closer (and clearer) than they normally appear.
Randy
2013 Rockwood A128S
Ford Ranger
Old 08-29-2012, 12:10 PM   #27
TURBS's Avatar
What's some good tips for using the panoramic feature ?
Old 08-29-2012, 01:05 PM   #28
chucker25's Avatar
Turbo
My cameras do not have the built-in pana mode however I have used it on other cameras a few times. "In-camera" pana is very cool and in the Fuji X10 I used it was amazing. I think it probably varies a bit camera to camera so i'm not sure what kind of tips to offer, especially given my limited exposure.
Generally the use of a tripod I would think would always be a good bet.
Be mindful of the 'over-lap' required if your camera requires you to take individual shots (some you just click once and swing the camera, then let go).
If you have a choice always use the slowest ISO speed you can get away with to help increase final output quality - pana's tend to get printed on larger than normal paper so you want to eliminate the 'grain' look if possible.
If your camera allows it use the vertical orientation (portrait) of the camera during the pana, you can always crop later. This way you get max amount of image up & down as well as left/right of course.
Play with it and have fun. Pana's are the type of picture that the more you do them, the better you will get. Each camera will have it's little quirks so practice, practice, practice.
Randy
2013 Rockwood A128S
Ford Ranger
Old 08-29-2012, 01:17 PM   #29
TURBS's Avatar
Originally Posted by chucker25
Turbo
Randy
Thanks Randy,
I've used it a once to try it and yes you click the shutter once then start panning.
Although I did it without tripod it seemed to work well.
I'm going to try it this weekend of the cg and we'll see how it works.
Thanks for the info.
Ron
Old 08-29-2012, 03:58 PM   #30
great white's Avatar
Camera: Nikon D3X and a D4.
Lenses:
normal length
Long length
Wide angle
macro
Whole bunch of other lenses I have no idea what they're for.
Plus: more flashes, shields, reflectors tripods and timers/remotes than I know what to do with.
But those are the wife's bits.
If you haven't already guessed, she's a professional military photographer. Does everything from passport photo's to accident scene documentation, landscapes to portraits, macro to telephoto, combat camera to diplomatic, seriously disturbing stuff to the "gripe and grin" snaps. She has a huge "portfolio" to pull out when anyone wants to see her work. There's also lots of stuff in there that people don't want to see......Heck, I'm military SAR and there's things in there I never want to see again.....
I use her older stuff (usually a D2X) and whatever lenses she still has around for it or one of the "point n shoots" we have lying around. Honestly, I usually also ask her to dial in the settings and then I point it or go on "full auto".
Lately, I find my iPhone 4 is doing most of the opportunity snaps because I just can't be bothered to carry all that other gear around....
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
