11-23-2013, 08:01 PM
Remotes don't work??
3 different remotes
1 Comcast
1 Magnavox TV
1 surround sound system
None of them will make anything happen
The sound system is separate yet I can't control it
Could it be a Ham Radio?
or the small airport that is about a mile away?
The shades are pulled and the screen brightness is turned down
I wiped the fronts of the remotes and the fronts of the boxes
A tech came over about 2 weeks ago and couldn't explain it - said it is an anomoly...
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
11-23-2013, 08:18 PM
What are you using to power to the 3 units?
11-23-2013, 08:45 PM
Wall outlet.
2 cords.
TV is plugged in to unswitched cable box outlet.
2012 Surveyor SV264
NW Oregon
11-23-2013, 10:08 PM
are you trying to use a Comcast cable box in a campground?
don't know where you're trying to use all these remotes. house or campground?
11-23-2013, 10:32 PM
I'm at home.
2012 Surveyor SV264
NW Oregon
11-23-2013, 11:01 PM
Just curious....did the remotes come with the devices you are trying to control? Have they worked in the past? If so, what has changed?
11-23-2013, 11:47 PM
Yes and yes.
I don't know of anything that has changed...
I can now turn the TV off and on and change the volume.
The cable remote works up to about 4 feet from the box - no more. It was only working within 2 inches.
The sound system still does not respond at all by remote.
Everything worked well for many months then about 3 weeks ago nothing worked by remote. Of course it all worked when the tech was here 2 weeks ago.
Things were fine for 2 weeks now there is almost no response... again...??
2012 Surveyor SV264
NW Oregon
11-24-2013, 01:40 AM
Just thinking out loud,
The devices turned on so they have power.
Remotes work when they want and not far away. Do the remotes have fresh batteries?
11-24-2013, 01:50 AM
Have you added any motion sensors to the house? Some, but not many, emit infra-red and it can desensitize a remote control pickup. Any other new electronics in the room the devices are in? Try unplugging all but one device and try it's remote. Go through all 3 that way.
11-24-2013, 07:04 AM
That is very strange.
Maybe you need an exorcism!
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
11-24-2013, 07:23 AM
Have to agree, put new, fresh batteries in all the remotes.
11-24-2013, 09:09 PM
Evereddie led me down the path!
The remote to the sound system didn't work at all so I pulled the batts out and then the other 2 worked.
Took it apart and found a piece of conductive coating from the back of a "button" laying between 2 contact points. Removed it and now all 3 work
It was putting out a constant signal that blocked or interfered with the other devices.
2012 Surveyor SV264
NW Oregon
11-24-2013, 09:30 PM
Glad I inspired a fix! I am a broadcast and communications engineer and you wouldn't believe how may times I found a piece of equipment messing with other equipment around it. Even if that piece of equipment appeared to work good. In your case you knew one piece was bad already.
