Old 03-26-2013, 02:19 PM   #1
Scare Lights
For those that use them, I had the rare occasion to use ours for the first time in Florida and all I got was a flash and no light. After digging out the caulking from the lense screw holes I replaced the bulb and decided to clean the other one out when I got home and had a taller ladder.
I don't know who the "Einstein" was that decided that the lense screw holes needed to be caulked shut, but they made sure they even filled the "X" slots in the screws. Brilliant! Only took 45 minutes to dig the 4 screws out using a drill bit, pick, pocket knife, flat screwdriver and needle nose pliers. Whomever did the caulking did an 'A' no. 1 job. He filled them full!
Name:	Scare Light Before.jpg
ID:	26461   Click image for larger version
Name:	Scare light after 45 minutes of digging.jpg
Old 03-26-2013, 02:21 PM   #2
rattleNsmoke's Avatar
And the guy prolly had a good laff after doing it too. I not so sure about some of these 'quality' Amish.
rattleNsmoke is offline   Reply With Quote
Old 03-26-2013, 02:25 PM   #3
My scare light bulb didn't last long. I don't remember having the other issues you did though.
Len & Cheri is offline   Reply With Quote
Old 03-26-2013, 02:29 PM   #4
I thought just the lens came out after the installation ?
I have two of them and will install them exactly the same ! No water is going through anything ! The screw tops etc will be covered with sealant !
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 03-26-2013, 02:30 PM   #5
Always Learning
Isn't this the second time you did this?
Scare Lightbult replacement
Old 03-26-2013, 02:32 PM   #6
Yes, I just remembered to finish what I started in FL.
Old 03-26-2013, 02:32 PM   #7
TURBS's Avatar
He's old he can't help it......
He's got B syndrome
Old 03-26-2013, 02:35 PM   #8
Phat Phrog
RVChick's Avatar
I have three outside light fixtures that have condensation in them....I guess that guy didn't caulk mine properly!!!
Kenny n Karen
TV: 2017 Chevy Silverado 3500 LTZ - named Betty
RV: 2017 Columbus 366RL - named Karen’s Camper
RVChick is offline   Reply With Quote
Old 03-26-2013, 02:39 PM   #9
I can see filling the hole with a silicone paste like Danco Silicone Grease like I did, just not with caulking, and why fill the "X" in the screw head with caulk also?
Old 03-26-2013, 02:43 PM   #10
Bone Dry! Youroo!!
Name:	nite snow 021.jpg
Old 03-26-2013, 02:53 PM   #11
Have DH remove the lenses and apply a good coat of Danco Silicone Grease on the lense edge and re-install. Then fill the cavity with the silicone grease. You can get the grease @ Lowes or HD.
Old 03-26-2013, 02:59 PM   #12
Phat Phrog
RVChick's Avatar
Originally Posted by OldCoot View Post
Have DH remove the lenses and apply a good coat of Danco Silicone Grease on the lense edge and re-install. The fill the cavity with the silicone grease. You can get the grease @ Lowes or HD.
Will do! Thanks OC!
Kenny n Karen
Old 03-26-2013, 03:02 PM   #13
B47
He's got B syndrome
Boy you just can't let go, can you?
Old 03-26-2013, 03:05 PM   #14
Phat Phrog
RVChick's Avatar
If he did, we would worry about him!
Kenny n Karen
Old 03-26-2013, 03:08 PM   #15
That's OK B, just consider the source. At least we do something besides going to a business establishment and pretend to work while messing around on a confuser all day and half the night while his DW is out slaving away trying to keep the home fires burning.
Old 03-26-2013, 03:09 PM   #16
What is a scare light? Thanks
Jim Scofield is offline   Reply With Quote
Old 03-26-2013, 03:12 PM   #17
The big round clear lense useless lights usually mounted high on the trailer pointing out into no where except in your neighbors eyes.
Old 03-26-2013, 03:12 PM   #18
B47
true - he told me what his job consists of and why he has all this free time, but now I am wondering about that also.
Old 03-26-2013, 03:22 PM   #19
DAISY BOYKIN's Avatar
There you go-----------------
There you go messin with B-47 again. One day you will wake up wich
B-47 staden over youse with a big ball bat!
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
DAISY BOYKIN is offline   Reply With Quote
Old 03-26-2013, 03:26 PM   #20
Replaced scare lights-----------------
I replaced my scare lights when the white frame work began to show rust!
The scare lights are available in stainless steel for the round ones. When re-installing the lens, make sure the drain hole is at the bottom when mounted. Do not caulk drain hole!
2019 WILDCAT 28 SGX
