Old 11-14-2015, 02:52 PM   #11
AquaMan's Avatar
Originally Posted by dwhit View Post
mcnabbwr-There was still pressure on this fitting despite the draining and blowing-out the system. I removed it and sprayed it w/WD40. Works now.
Surprising how much hate a little fitting like that can build up.
I do this quite frequently and was about to mention it earlier, but got sidetracked.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 11-14-2015, 03:00 PM   #12
mcnabbwr's Avatar
Glad you got it figured out.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 11-16-2015, 11:16 AM   #13
I too had problems and used the wd 40. Part of the problem for me was when the dealer winterized out camper, the ports weren't properly winterized. There is an 3/32 -1/8 diameter pin in there. Water would collect around that on and rust over the winter and be hard to move and then leak come spring once water pressure was applied to the system
OKI Marine is offline   Reply With Quote
Old 11-16-2015, 05:58 PM   #14
dwhit's Avatar
Location: Chicago, Rochester now GA/SC at Lake Hartwell
I spoke with the original owner about it...they never used it. I'll bet the problem you described was also affecting this one. It was locked-up solid 'till I removed the fitting and filled the female end w/WD40...
XLR 415AMP, F350 Lariat 6.7 DRW, three bikes, NRA Benefactors.
Heart issues-laid up for a spell
dwhit is offline   Reply With Quote
