Old 11-03-2014, 07:04 PM   #1
The best mod you've made to your camper
What would you list as your top 5 mods that you've made to your camper that benefit you the most?
Old 11-03-2014, 07:09 PM   #2
TURBS's Avatar
Remote awning mod.
Surge guard mod.
Marker light led mod.
Dual batteries w/ trickle chargers.
homemade strong arms.
Top 5
Turbs
Old 11-03-2014, 07:14 PM   #3
BombDoc's Avatar
OC's awning support poles.
EMS Surge protector.
Jt Strongarms.
Slide out toppers.
OC's step extension for the Mrs.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is offline   Reply With Quote
Old 11-03-2014, 07:15 PM   #4
1- Added a set of speakers in the master bedroom.
2. On our 2013 SP 260 the television rotated clockwise. I re-did so it would rotate counter clockwise to make it better viewing from the dinette.
3. Installed a 20 inch long, 1/4 inch wide strip of reflective tape centered and plumb in the front of our camper. On my rear window I have an inverter V. I use that for line up when backing in to hook up the camper.
4. Glued small pieces of 1/4 plywood behind many of the stripped screw through out our camper.
5. Command Hooks!
Since the thread is top five I wont number the ones I forgot about, LED interior bulbs, and I rekeyed all the outside locks match the key on my tonneau cover.
2017 Keystone Cougar 28RDB
Buck1032 is offline   Reply With Quote
Old 11-03-2014, 07:15 PM   #5
I will throw in my top 3 mods to the new Hemisphere.
1: 123 Watt solar charging system
2: 2 Interstate 6 volt golf cart batteries to store much more juice than the previous 2 - 12 volt.
3: LED interior bulbs
Dry camping is a pleasure
Obrieri is offline   Reply With Quote
Old 11-03-2014, 07:20 PM   #6
An oxygenics shower head has been the best mod so far. Better than my shower at home.
motodude79 is offline   Reply With Quote
Old 11-03-2014, 07:34 PM   #7
HONDAMAN174's Avatar
Added a light to the shower for DW and shower rod extender.
Custom BBQ grill mount off back bumper.
Led's to the awing.
Entertainment center running off power inverter when "roughing it" dry camping.
TPMS and "D" rated tires
Progressive industries power protector.
Changed all locks to one key- NOT a 751
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 11-03-2014, 07:41 PM   #8
kho6658's Avatar
Single Upper bunk to double bunk
Memory form mattress in front bedroom
tv in the front bedroom
LED outside lights
Changed all locks to the same key as entry door.
2016 Freedom Express 28SE
2017 F350 Lariat
Days Camped 2018 - 6
Days Camped 2017 - 41
kho6658 is offline   Reply With Quote
Old 11-03-2014, 07:52 PM   #9
Phat Phrog Stunt Crew
elind's Avatar
Hardwired surge protector.
JT Strongarms.
Remote keyless door opener.
Second A/C.
WIFI booster.
Awning support poles.
New bed
Soda frig in basement.
plus a dozen additional shelves
and more to come!!
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 11-03-2014, 08:06 PM   #10
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Jack antenna system
TPMS
Keyless entry lock
Shut off valves to fresh and grey water tank drains
Awning shade
OC; What are your top 5 mods?
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is online now   Reply With Quote
camper, modifications
