Old 12-14-2014, 08:30 AM   #31
Dodge Guy's Avatar
Originally Posted by B47 View Post
Part of the certification process. There's probably some stuff on the net that shows wings breaking during certification testing.
If the wings were rigid,they would fail during loading in flight. Remember the wings are supporting the entire weight of the airplane in flight.
Some triva - I read that the wings on the B47 would bend about 6-7 feet at the wing tips and the B52 wings would bend about 14-16 feet at the tips. Goggle "Flying The B47" and you see some wing deflection.
Yes, but what happens when you bend a piece of metal a few thousand times? think of a coat hanger!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 12-14-2014, 09:43 AM   #32
Dazed & Confused
M&K Hoffman's Avatar
Originally Posted by CSMRetired View Post
A pilot once told me. ...
The 'only' thing that makes a plane fly.....is 'noise'
Think about that for a while
As a private pilot I can tell you it is large sums of cash that make planes fly.
BTW the planes I fly have large fans right on the nose to keep the pilot cool. Really, cause if the fan quits, the pilot is gonna sweat!
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 12-14-2014, 11:07 AM   #33
Infractee
Gliders don't have engines
Exactly
RhoZeta is offline   Reply With Quote
Old 12-14-2014, 11:45 AM   #34
B47
Large sums of cash ...?
I'm not a pilot,but I can tell that no amount of cash is ever enought to repair an engine that stops running inflight while inflight.
It takes proper maintenance on the ground to keep an airplane airworthy which does cost some large sums of cash.
Old 12-14-2014, 12:08 PM   #35
B47
Good question - just remember that airplanes ( and rotorcraft) have a great amount of engineering go into the certification process before they are certified for use.
That's one reason that wings are stressed to their breaking load. The wings are highly instrutmented and data recorded during the process. I'm not an enginner, but I know that the data recorded during the process is recorded and used to come to what the wings are capable of hand,ing.
In addition,aircraft are certified with a maximum service lift - that being the amount of flight hours and cycles that it can be flown before it has to taken out of service. This service life is often extended though data recorded during operation and with FAA approval,is extended.
Also certain components of an aircraft are listed as "lift limited parts" and these parts have to be replaced when they reach a certain point.
In addition,the aircrafts maintenance programs will contain requirements to keep the aircraft airworthy.
So in summary - aircraft are not ever just rolled out the factory door never to be seen again - the FAA,the manufacturer and the airline are constantly monitoring it.
These much more to this and if you wish to know more,PM me and I will provide reference to the regulations covering this.
Old 12-14-2014, 03:15 PM   #36
RKR
RKR's Avatar
Landed crossed up similar to Turbs pic in Vegas once. I had a window seat and when while looking out the window I could see the runway ahead. At the last second the pilot kicked her over straight and we landed. Helluva pilot in my mind.
Sent from my high tech gadget
RKR is offline   Reply With Quote
Old 12-14-2014, 09:03 PM   #37
Infractee
Good thing aircraft are not made out of coat hangers then, eh?
Old 12-14-2014, 09:07 PM   #38
B47
And a good thing that aircraft bend and not break.
Old 12-15-2014, 04:51 PM   #39
Dodge Guy's Avatar
Well I guess I should be happy I hang my clothes on hangers and not an airplane! LOL
My Coat hanger post was more tongue in cheek than anything, but thanks for the lesson in airplane building and certifying techniques!
I know I will never get a window seat again after watching a wing flex for 4 hours!!!!
07 Cherokee 32B
Old 12-15-2014, 05:09 PM   #40
B47
No problem from me.
The wing flex isn't readily visible on commercial transport category airplanes. It's most noticeable during takeoff when the wings take the load and landing when the wings lose the load,but there is some flex.
One other thing - Boeing pioneered the concept of placing wing mounted engines on pylons with the B47. They found that the engine/pylon combination helped reduce wing flexing. This design was later adopted by other airplane manufacturers for their swept wing airplanes,both military and civil.
