Old 10-21-2015, 04:36 PM   #451
Herk7769's Avatar
Still hoping there is a "Lockheed Fix" and the catheter starts working again.
If not HHD is the way to go. I was told it uses about 17 gallons of water per treatment (plus the supplies) and it will take a minimum of 6 weeks for her port to heal enough to use it. That means a temporary portal for clinic Hemo until the fistula heals.
Lots to think about.
The nurses think it may be a large blood clot blocking the catheter and the tried to flush it this afternoon (4 hours working on her) with a "clot buster" drug similar to the one used for strokes. We will know more tonight if that was sufficient to continue with PD for the time being.
Fingers crossed.
HAM CALLSIGN - KC3FFW
Old 10-21-2015, 05:15 PM   #452
Lost Vermonters's Avatar
I hope her cath clears also.
But 17 gals is way off. I am a BIG boy and i use 40 liters of dialysate. Thats about 10 gals. It depends on her prescription which depends a lot on her size.
Whoever said size is like large copier is correct. And the portal you mention, yes it needs 6 to 8 weeks to heal and enlarge to start using. Then it will enlarge more and run at faster flows. But they can install a chest cath in the meantime
And BTW if you are not comfy doing in home there are clinics all over. Travel coordinator at home clinic can arrange a spot
After 17 years gone - Finally moved back to Vermont 2016.
2015 Microlite 21 FBRS
Silverado 1500 TV
Lost Vermonters is offline   Reply With Quote
Old 10-21-2015, 05:49 PM   #453
GlacierGus's Avatar
Our thoughts and prayers are with you always.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 10-21-2015, 06:07 PM   #454
Thoughts & prayers form Beth and I, we also really need to plan a get together soon!!!
dblr is offline   Reply With Quote
Old 10-21-2015, 07:20 PM   #455
Herk7769's Avatar
Initial drain tonight shows large clots coming out.
Believe it or not, this is a good sign. Time will tell.
Old 10-21-2015, 07:25 PM   #456
The Mustard Seed's Avatar
Our Prayers
from NE Ohio....
Hunter & SweetC
2 Wild Westies - Brody, Morgan
2012 Ford F-250 Super Duty 6.2 Liter
2014 Palomino 30RKSS-1S Travel Trailer
The Mustard Seed is offline   Reply With Quote
Old 10-23-2015, 07:50 AM   #457
Platokidd's Avatar
Location: Home of the 2016 WORLD SERIES CHAMPIONS CHICAGO CUBS
More prayers from Illinois
2014 LaCrosse 323RST-TE-C
2009 CHEVY 2500HD Silverado Z71
2016- 92 nights of camping
Old 10-25-2015, 11:21 PM   #458
asquared's Avatar
Any further updates on Laura?
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 10-26-2015, 10:01 PM   #459
Herk7769's Avatar
At 10:40 EDT tonight I got home from the hospital and need to be back at 6:30 tomorrow.
She had surgery tonight to have her PD catheter replaced and a chunk of her Omentum removed that had been blocking it. The surgery last Friday was supposed to cure the intermittent clogging by tacking up the offending piece of Omentum but another just slid into its place and jammed up the works good.
The planned 30 minute "peek and flush" turned into a close to 3 hour ordeal where the Omentum that could even remotely get in the way and the old plugged catheter were removed.
Our girl is in a bit of pain and is in a horrible mood.
(Half German, half Polish) go figure.
I really feel sorry for the nurses and doctors who have felt her ire.
(Though some have earned it!)
18 hour "advocate" days are starting to wear on me, but with any luck at all she should be home to recover tomorrow night. PD to start again next Monday (unless she needs it sooner - there is a special PD protocol for PD before the catheter is fully healed).
She is not taking calls from family yet so if you have her number please don't call. I will post when she is feeling up to chatting.
The surgeon is pretty happy with the new catheter placement and feels very confident it will work as advertised (but time will tell). It looks like we ducked the Hemodialysis bullet this time. With luck we will get the call for a new kidney before we need to do a repeat of this last 10 days.
Thank you all for your prayers and well wishes, Laura and I really do appreciate them and we want to let you all know they did the trick.
Lou and Laura
Old 10-26-2015, 11:18 PM   #460
Herk,
Our thoughts and prayers are with both of you. Hopefully they will find a match soon.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
