Old 02-26-2015, 01:14 AM   #1
Tires cupping on Continental Cargo Trailer
On Continental Cargo 16K Gooseneck, with Al-ko 800E 8 K axles.
Tires are cupping badly on all 4 tires, some worse than others.
Not sure where problem lies
Torflex axle
Tires
Bearings
Alignment
Loading
Has anyone else encountered this problem?
gary48 is offline   Reply With Quote
Old 02-26-2015, 05:00 AM   #2
Not having been balanced is the main cause. Balancing now will not eliminate the damage already done either.
Old 02-26-2015, 10:41 AM   #3
cogito ergo moo
Cowracer's Avatar
Bad/lack of shocks will also cause tire cupping. Do you regularly rotate your tires (side to side)? I think that is a very important issue on a trailer. My flatbed (no shocks) would cup tires in just a few thousand miles. I started swapping them side to side every 3-4 months and now they last a lot longer.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 02-26-2015, 10:45 AM   #4
TURBS's Avatar
Originally Posted by Cowracer View Post
do you rotate tires (side to side)? I think that is a very important issue on a trailer. My flatbed (no shocks) would cup tires in just a few thousand miles. I started swapping them side to side every 3-4 months and now they last a lot longer.
Tim
I agree.
Old 02-26-2015, 10:55 AM   #5
Lack of shocks and swapping sides will still not cure the cupping until you balance the tires and check the suspension, brgs, etc.
HOW TO READ TIRE WEAR
Old 02-26-2015, 11:03 AM   #6
Ret E-9 Anchor-clanker
donanddona's Avatar
One a wear pattern is established it is there for the life of the tire.
donanddona is offline   Reply With Quote
Old 02-26-2015, 11:05 AM   #7
100% TRUE!
Old 02-26-2015, 11:09 AM   #8
TURBS's Avatar
Originally Posted by OldCoot View Post
100% TRUE!
I beg to differ once again.
We rotate our drive tires "side to side" on our peterbilt, mack and cranes because they get "torque cupping" and the cupping always come out.
Old 02-26-2015, 11:15 AM   #9
Guess what Dude, we be talking about trailer tires, which are not subjected to "torque cupping". Go back to sleep!
Old 02-26-2015, 11:16 AM   #10
TURBS's Avatar
Same principle!
Cupping is cupping!
Turning the tire around to rotate it in the opposite direction is the answer!
TURBS
tire, tires, trailer
