Suspect 2013 Sunseeker has same water heater as our 2012 Solera - gas/electric 6 gallon Suburban.
First thought - as it is gas and/or electric, does it work on alternate power? That is, if it doesn’t heat on gas, does it heat on electric? Vice versa?
It needs 12 volts to work. 12volt house battery okay and switch turned on?
There is a circuit breaker in the 110volt circuit. If the problem is only when on 110volt, maybe breaker is tripped?
If the 110volt doesn’t work, but gas does, you can just run it on gas; ditto on electric if gas doesn’t work but electric does.
JLeising
2012 Solera "S"
Calif SF Bay Area
