Old 08-11-2015, 09:21 PM   #41
Originally Posted by Crusadernoob View Post
How do you like it? I currently am using a Ranch adapter. No cushion, nothing so I feel every jolt. What is the weight capability for this?
OKI Marine is offline   Reply With Quote
Old 08-11-2015, 09:34 PM   #42
Crusadernoob's Avatar
I believe it is rated to 16k, I love it, smooth, it was a tough decision for us on what to buy as we had a ball in our truck. Glad I went with it. Just food for thought, it is no longer a fifth wheel so safety chains are needed, required in most states. As far as jolts you speak of, it takes a pretty nasty bridge joint to shake things up, but it smoothes out very quick. This is also the only goose neck adapter that doesn't void the frame warranty, per Lippert.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is online now   Reply With Quote
Old 08-11-2015, 09:35 PM   #43
I guess the most useful mod would have to be the handrail I made for TOWTA and real close behind it would be the awning poles as we always deploy the awning. Those 2 mods are the most beneficial to us.
Old 08-11-2015, 10:10 PM   #44
Blackhat6mike's Avatar
#1 Solar System 6 x 100 watt panels and 50 amp controller.
#2 Removed the 80mm fan on the rear of the refrigerator and installed two "quiet" 120mm fans. Huge difference in noise and cooling.
#3 Larger water pump.
#4 Two additional 125 amp hr batteries and vent fan.
#5 5000 watt Inverter
#6 Converted fake vents over and under bedroom TV to linen cabinet [upper vent] and liquor cabinet [lower vent].
#7 Two wall mounted rotating fans in bedroom. [White noise for DW and moving air for me].
#8 Five inch PVC tubing in rear outside locker to store extra sewer hoses.
#9 Lexan panels between roof and awning to keep out rain under awning.
#10 Got rid of jack and jack stands for a roll on wedge for changing flats.
#11 Three "Scare Lights".
#12 Digital temp gauge with on/off toggle switch on refrigerator for both refrigerator and freezer so I don't have to open doors to check temps.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 08-12-2015, 09:30 AM   #45
One more question. What is the weight of your camper and tongue weight? I'm a little over 14,000 lbs I'm told when looking at hitch systems that I should go with 20k. Seems like over kill to me. I would think the 16k would be sufficient. Can you please shed any light on this?
Old 08-15-2015, 02:25 PM   #46
Georgia Frog Rally 2018
aceinspp's Avatar
So far 6 mods. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
modifications
