-   -   Electric fireplace won't turn on (http://www.forestriverforums.com/forums/f96/electric-fireplace-wont-turn-on-100518.html)
mikejm 02-05-2016 11:06 PM
Will do.
mikejm 02-06-2016 05:00 PM
All gfi's are good. Can't find were fireplace electric cord receptacle is or to see if that plug is good. Thanks, mikejm
TURBS 02-06-2016 05:06 PM
http://uploads.tapatalk-cdn.com/2016...eaf5a92369.jpg
Pull your drawers out.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
mikejm 02-06-2016 05:14 PM
Found the plug, thanks! Unplugged, plug good, plugged back in, nothing. Is there another place to check?
bob caldwell 02-06-2016 05:16 PM
Gota be a plug....behind something...Did you check the plug-in for power/
mikejm 02-06-2016 05:18 PM
None of the breakers are off but no chart for what breakers or fuse may give power to fireplace.
bob caldwell 02-06-2016 05:21 PM
PLUG a light in to know if there's power there at the plug....
fonzie 02-06-2016 05:22 PM
Some fireplaces are interlock with microwave so these don't run at same time. An auxiliary relay is use. Could it be a possibility in your case?
http://www.forestriverforums.com/for...ave-70247.html
mikejm 02-06-2016 05:35 PM
No have used both simultaneously flipped that breaker anyway still no power to fp
