-   -   Removal of Motor on Lippert Awning (http://www.forestriverforums.com/forums/f228/removal-of-motor-on-lippert-awning-101597.html)
Teamfour 02-24-2016 12:30 PM
I need to remove the motor from my Lippert Solera awning. Either a gear has a bad tooth or their is a dead spot in the motor. Anyway, is it possible to remove the motor without the awning unwinding or creating some other unintended consequence?
rracer5 02-24-2016 01:13 PM
I'm not familiar with Lipperts awning but, I do have experience with Dometic. Your awning may be "pre-loaded" to assist it retract. There may/should be a process to "pin" the roller so when you disengage the motor the spring doesn't unwind. :eek:
Solera® Power Awning
