-   -   Tv mount (http://www.forestriverforums.com/forums/f113/tv-mount-102707.html)
TysonTDW 03-10-2016 07:08 PM
Tv mount
First post, first ?
Just got a 2016 2702WS
It came with a tv mount on the outside.
TV in aide is all bolted in so it does not seem like I can use the inside TV.
How does this work? Should have I recieved another part of the bracket to for a TV
http://imageshack.us/photo/my-images...041500134.jpg/
AquaMan 03-10-2016 07:14 PM
Does the outside bracket look like a "V" slot? If so, the inside TV most likely has the same mount. It can be a bit stubborn at times to remove. Try lifting firmly.
TysonTDW 03-10-2016 07:23 PM
Not the V slot. Two circular slot holes.
Is there not an image in the OP?
Oaklevel 03-10-2016 07:40 PM
Similar to this????
Oaklevel 03-10-2016 07:53 PM
2 Attachment(s)
Inside mounts on main TV :) Thought at first it would not come out but found the mount to be as pictured behind the main TV.
TysonTDW 03-10-2016 07:55 PM
Hum, guess you all cant see the pic in the OP. I can see it for some reason
But yes, like that but black. How does it work?
Thanks.
TysonTDW 03-10-2016 07:57 PM
Awesome!!!!! Thanks. I didn't assume the entire arm would come out. I'll look at it again.
First post a success. I.like this forum already!!
MKClark 03-10-2016 07:57 PM
Sounds like you have the mount that Forest River gets from:
Ramco Engineering,Inc.
2805 Frederic Drive
Elkhart, IN.
800-321-4819MSCSL12-QD.
Bought one for our bedroom to match the outside bracket and what the main TV is
mounted with.
________________
MK Clark
2819VS Windjammer.
MKClark 03-10-2016 08:01 PM
Oaklevel that is what we got from Ramco.
MK Clark
