-   Wildwood (http://www.forestriverforums.com/forums/f30/)
-   -   making room to open the tailgate (http://www.forestriverforums.com/forums/f30/making-room-to-open-the-tailgate-102979.html)
5LowesOR 03-14-2016 05:09 PM
Has anyone tried to turn the electric jack so that the tailgate can be opened when the truck is connected to the trailer hitch? or if the whole unit can be unbolted and spun for better clearance?
I appreciate the feedback.
bob caldwell 03-14-2016 05:10 PM
Been other threads and posts of folks doing it
youroo 03-14-2016 05:31 PM
Some Brands of Elec.Jacks,the motor can be turned,some Members if they Only need "1-2"" to clear the Jack drill another 5/8" hole "Downstream" in the "Ball Mount" shaft! Some Ball Mounts come with two 5/8" holes in them! :thumbsup: Youroo!! :us-flag-waving:
5LowesOR 03-14-2016 05:53 PM
I will try some further searching. ty
bikendan 03-14-2016 09:22 PM
I was able to turn my UF 3500's motor 180 and now have no problem dropping the tailgate.
asquared 03-14-2016 09:25 PM
Between this forum and some other forums, I have seen it done.
5LowesOR 03-15-2016 09:55 AM
I read where it had been done as well. Sounds like you can unbolt the entire unit and rotate it. If the motor/electronic box itself can be turned that would be just as good in my opinion. I will have to look at what brand mine is at home. Wait for a dry day and see what i can get done.
dalford 03-15-2016 10:02 AM
Yes, the jack does motor does not care what way it faces...
youroo 03-15-2016 10:04 AM
Barker units allow Head rotation also! The Bolt Base pattern will NOT allow Jacks to be located in the location you desire! :crying: Youroo!! :us-flag-waving:
OldCoot 03-15-2016 10:44 AM
As a last resort, if the motor can't be turned, just take it to a welding shop and have the mounting plate cut off, rotated and re-welded. Shouldn't take but about 30 minutes start to finish.
