-   A Frame Campers (http://www.forestriverforums.com/forums/f221/)
-   -   LED Lighting (http://www.forestriverforums.com/forums/f221/led-lighting-104035.html)
s2111 03-28-2016 05:51 PM
LED Lighting
I would like to switch my interior lighting over to LED. I know the size is #921. Has anybody here switched? If so, what brand should I look up on amazon.com TIA
heavynlori 03-28-2016 08:18 PM
Attachment 103143we replaced our 921 with these
Sent from my iPhone using Forest River Forums 🇺🇸
s2111 03-28-2016 08:32 PM
Ok thank you
crunchman12001 03-28-2016 08:47 PM
I switched all mine out with these. 20x Warm White T10 921 194 RV Trailer 42 SMD 12V Backup Reverse LED Lights Bulbs | eBay $19.99
These are warm white 4000-4500 kelvin. (Easy on the eyes, like incandescent)
These have 42 led's per light so they are not as bright as 921's but close. If you want brighter lights go with the 68-SMD'S.
I had 3 that blinked, the seller replaced no charge. These must be polarity sensitive, put some in one way did not work, flipped them over and worked fine. Very cool burning lights, low watt no heat.
Highly recommend.
crunchman
As far as brand...they all come from China and are rebranded.
royboy334 03-29-2016 09:14 PM
goto superbrightleds.com and you have a choice of warm white, natural white, cool white
the 921 bulb has different light outputs, warm white the giving out the least light and cool white giving the brightest light. I got six including shipping for $29.95
JoArt 04-02-2016 01:13 AM
We installed LED lighting a couple of years ago and find it pleasant. We have one warm light and one bright white in the ceiling mounted light fixtures. They work with each other to give us the best of both their worlds.
Mountain Girl 04-03-2016 05:52 PM
We want to change ours to the warmer light. In a small area the regular light is too bright. Thanks for the information on changing them.
757Dave 04-03-2016 06:11 PM
Here's an earlier thread on this same subject. Lots of good suggestions to look through...
http://www.forestriverforums.com/for...de-103721.html
Happy travels!
:signhavefun:
Skyliner 04-04-2016 01:05 AM
Cheap Ebay LEDS mentioned in earlier post have worked for me for years.
In hallways and main areas, I use these which are brighter and throw good amount of light: 10x Warm White T10 BA15S 1156 LED 48SMD Panel Interior Dome Map RV Trailer Light | eBay
FOr areas above seating areas I use these too: 20x Warm White T10 921 194 RV Trailer 42 SMD 12V Backup Reverse LED Lights Bulbs | eBay
Only failure I've ever had was double sided tape coming undone which I fixed with 3M tape from a retail store.
