-   Cherokee (http://www.forestriverforums.com/forums/f24/)
-   -   Tv mount for interior? (http://www.forestriverforums.com/forums/f24/tv-mount-for-interior-105246.html)
Ledzeppelin72885 04-08-2016 12:06 PM
We have an exterior tv mount for our 30" that came with the camper. I have an 18" tv from our old pop up that I would like to mount inside. There's sufficient wall space over the bed. Is it possible to install a new mount? Perhaps a swivel so everyone can see it? We're not sure how sturdy the walls are of if there is studs to mount it to. Also, is it possible to add an electrical outlet? New to enclosed campers. Have no idea what we're doing!
2015 Cherokee wolf pup 16BHS
BooBoo23 04-08-2016 12:42 PM
I will assume your 18" TV is a flat screen. If so it probably doesn't weigh much over 7 or 8#. If there was no tag on the wall saying where you could mount a TV then there is no backer board in place. You could possibly mount on the wall if you can find the studs. Spacing of the studs is not predictable. With a light weight TV you should be able to mount on the wall BUT it would be best to remove the TV from the wall when traveling/moving as the bouncing up and down would rip it off the wall. You may want to contact someone at the factory where it is made to get more specific specs on how the wall constructed where you want to mount the TV. In any case you shouldn't use any screws that are more than 1 1/2" in length. As far as the electrical outlet it my be just as easy to use and extension cord for temporary use of the TV.
Perhaps someone who owns a TT like yours has already done what you are asking about and can provide photos of the project.
Ledzeppelin72885 04-09-2016 09:12 PM
Haha do they even make anything else besides a flat screen anymore?
2015 Cherokee Wolf Pup 16BHS
'94 Ford F350
Mike Lynn 04-20-2016 10:56 AM
I'm trying to locate safe mount/bracket on 2015 371rebh bedroom and den. No location labels when I picked up coach. Any thoughts?
ladypmd03 04-22-2016 02:33 PM
We just bought the Cherokee 16 BHS
Was wondering the same thing?
Love to see some mods to mounting a tv
dmacalli 04-22-2016 03:44 PM
2 Attachment(s)
Hi there...
Our bedroom wall does have the backer (Cherokee 274DBH), and it does work very well. See some shots with the tv mounted...
allmine4x4 05-30-2016 02:15 PM
Tv mount
Originally Posted by dmacalli (Post 1173057)
Hi there...
. What kind of mount did you use ?
dmacalli 05-30-2016 02:24 PM
Hello... For the info on the mount I used, please check the thread (link) below (I hope the copy/paste worked). As additional info, we have traveled now twice (2 camping trips), left the TV up, and it has not moved... Very solid.
http://www.forestriverforums.com/for...ml#post1171196
bakwoodj 06-01-2016 08:30 PM
I posted my 22" TV on the end of the cabinet near the door. I used a swivel mount so the bunks can see it too. I had to brace the walls of the cabinet to carry the weight. See the link s in this post to see my pictures.
http://www.forestriverforums.com/for...ods-74851.html
bakwoodj 06-02-2016 11:41 PM
Led, I checked the wall above the window at the foot of the bed. Mine has a stud right in the center of the wall! So you could probably mount the TV there. If I were to putine there, I'd take a piece of 1/4" or Luan plywood and cut it the lenght of the wall right there so I could anchor the plywood to 3 studs and mount the TV to the plywood. Maybe make the plywood 4 to 6 inches wide and whatever length would be needed to catch the 3 studs. Even a 1x4 or 6 would work. You could paint it to match the wall or stain it to match the cabinets. Or cover it in cloth that matches the bed spread. I used a pillow sham that we weren't using to make my utensil holders. If this doesn't make sense to you, I can draw it up or post pictures to better explain.
