-   -   Wheel torque on my trailer? (http://www.forestriverforums.com/forums/f219/wheel-torque-on-my-trailer-106813.html)
Wingdreamer 04-27-2016 12:07 PM
My 2015 Vibe is about to get a full wheel bearing repack this afternoon, and I havent been able to figure out what the wheel/rim retorque is supposed to be. Anyone know? Really dont want to guess.... thx!!!
hondo 04-27-2016 12:36 PM
The sticker on ours says 90-95 ft lbs.
Scotty 04-29-2016 01:11 PM
I'm going to guess 90 to 100 ft lbs. However, recommend you pull down a Lippert or Dexter Axle manual it will give you the torque valve for each size wheel stud.
doc73 04-29-2016 02:22 PM
The amount is different whether Aluminum or Steel I believe. 95 to 110 for steel is what I have always read.
lbrjet 04-29-2016 03:35 PM
I use 90 on my aluminum rims. Important thing is to re-torque at 25 miles, 75 miles, 175 miles, 375 miles and then after that before each trip. Seems like about 500 miles on my trailer before before I no longer have one or two that still tightens at little.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
Wingdreamer 04-29-2016 08:15 PM
Mine are aluminum. Seems strange that forest River didn't put a sticker on the trailer right above the wheels with the torque spec.... Kind of an important thing to know....
doc73 04-29-2016 08:16 PM
Mine HAD one until it peeled off withing a few weeks. It was only a paper sticker, not so good.
OldCoot 04-29-2016 08:21 PM
FWIW, lug nuts/studs don't know the difference between steel and aluminum wheels.:roflblack:
Wobbles 04-29-2016 08:22 PM
Mine did. Paid attention to the spec, 100 pounds torque. Went and bought a cheap torque wrench and set it at 100 and keep it in the case, only use it for that. A little anal but it makes me happy.
No worries...
:signhavefun:
doc73 04-29-2016 08:26 PM
Not doubting your knowledge / expertise but, from what I have seen AL is 90 to 100lbs, steel 90 to 120. Must be reason somewhere. AL softer so less to avoid squishing? I dunno?
