-   -   What air compressor for RV tires? (http://www.forestriverforums.com/forums/f16/what-air-compressor-for-rv-tires-107526.html)
kenandterry 05-06-2016 09:01 AM
My RV tires have a requirement to inflate to 100psi.
Given the size of the cargo boxes in a Georgetown for carrying space, what model of compressor can best do the job? I would like to be able to inflate/top up tires in a reasonable time. This would be the only requirement for the compressor...NOT for air tools around the house.
Is there a minimum requirement for CFM or gallon size of tanks to consider?
Mikegjax 05-06-2016 09:09 AM
I just purchased this little compressor for my RV. Max output is 100 PSI. It is small and light so it meets my needs. Might take a while to fill a tire your size, but would be good for topping off.
Add says it is a DC compressor, but it is actually AC. I plug it into one of my outside 110 outlets.
Portables: HDX Air Compressors 2 Gal. Pancake Air Compressor 0210284C
ependydad 05-06-2016 10:08 AM
I have a Viair 450P and use it to top up my 125psi trailer tires (they're commercial trailer tires). I recently had to run a tire up from 108psi and it did it admirably.
It is 12v, which is good for me as I don't travel with a generator or big inverter. The negative for you is that it's powered by 2 alligator clips to clip right onto battery posts. I don't know how that works on motorhomes.
The Viairs are spendy, but fantastic products.
dphorton 05-06-2016 10:17 AM
I use this one. Craftsman 6 Gallon 1.1 HP Oil-Free Pancake Compressor 150 Max PSI with Hose & Accessory Kit. Sold at Sears and is currently one sale. It fits in my Georgetown 328 side Compartment .
RVnut 05-06-2016 11:05 AM
We have one to and yes they are spendy but work great on our 22.5 MH tires and we were at a KOA when a car had a very low tire so we helped them out so they could get to a tire shop.. The other nice thing is it comes in a handy bag and does not take much room
Jim34RL 05-06-2016 11:17 AM
I have a Dewalt 165 PSI 6 gallon air compressor with 30' of air hose, which works off of 120V 10 amp motor and has a adjustable air regulator. The air flow is rated at 2.6 SCFM at 90 PSI. I store this in the front compartment of my Cedar Creek basement.
ependydad 05-06-2016 11:24 AM
Do you mind me asking where/how you get power on a motorhome? Are the batteries easily accessible?
dphorton 05-06-2016 11:41 AM
There is a 120 VAC Outlet in the first Basement Storage Compartment nexty to the Steps on my 328 Georgetown.
clr 05-06-2016 12:14 PM
Many use this type of compressor, of course this unit does require AC to operate but is great to fill up or top off tires prior to departing a campground with services. Sears also sells the same unit but it is red of course.
Porter Cable Product Details for 150 psi, 1.5 gal Oil-Free Fully Shrouded Compressor - Model # CMB15
nomad297 05-06-2016 12:20 PM
I think it would be best if you told us what your source of electricity is.
Bruce
