-   Dynamax (http://www.forestriverforums.com/forums/f240/)
-   -   2016 Dynamax Force Brake Controller wiring, where is it ? (http://www.forestriverforums.com/forums/f240/2016-dynamax-force-brake-controller-wiring-where-is-it-108560.html)
724Bravo 05-18-2016 11:01 PM
2016 Dynamax Force Brake Controller ?
I can't seem to find the Brake Controller Wiring Harness under the dash.
Do I have to disassemble the dash to find it ?
Any help would be appreciated.
BLK-9 05-19-2016 04:17 AM
I think Halla indicated in a previous post it was located under the drivers seat. I'm sure he will chime in soon to validate the location.
FOURWHL 05-19-2016 10:06 AM
It's sitting on the gas tank below the cab on the drivers side. You have to pull a panel to get to it and then run it through the firewall.
halla 05-20-2016 11:17 AM
Yes gas tank below the drivers side. If you lay under the coach you can find red wire looms in the frame. I fed the cable through those, in through the firewall and hooked it all up.
2016 Dynamax Force. Just-Rite2
FOURWHL 05-20-2016 11:30 AM
Good idea!
Also there's room in the air brake panel knockouts in the firewall, which is what I used.
BLK-9 05-20-2016 11:05 PM
I found wire coiled up on top the drivers side fuel tank, but bringing/feeding it in through the air brake firewall is confusing to me. would you happen to have a picture available?
FOURWHL 05-21-2016 08:08 AM
Not near my RV so can't grab a pic.
Are you a Force or Force HD? Would probably be a bit different if you don't have air brakes.
Kenny kustom 05-21-2016 08:53 AM
All the force models have air brakes.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
halla 05-21-2016 10:30 AM
See the green, red tubes. This is on the drivers side left of the wire looms.
Attachment 108529
724Bravo 05-21-2016 11:28 AM
Attachment 108529
Is that the BC Loom in the Red spiral rap ?
Is the BC wiring separate from the rest of the trailer wiring or is it all together in one wiring loom ?
