-   -   AC Operation (http://www.forestriverforums.com/forums/f15/ac-operation-114055.html)
kdunn5005 07-23-2016 02:43 PM
AC Operation
Second time camping in our 2801QS. In Florida so the AC has been running all day. Is it normal for the AC to turn off for about 30 seconds and come right back on. It has done this quite a few times. Have the 15000 btu with heat pump. Had a 15000 in previous travel trailer and never had this happen.
Brian217 07-23-2016 03:24 PM
AC Operation
This has been covered many times on this forum. It has to do with the thermostat. You have it on auto, which will make it cycle from low to high. Change it to either low or high and it will stop the cycling.
Bama Rambler 07-23-2016 03:26 PM
Assuming you have the new digital thermostat, and assuming you're running it in Auto, it's normal for the fan to stop and restart when switching speeds. It will switch speeds when it either gets close to setpoint or gets farther away from setpoint.
kdunn5005 07-23-2016 04:22 PM
Thanks a lot for the information. Will change the thermostat.
