-   -   Dining slide out screams when it is going out and coming in. Have lubed both teeth arm (http://www.forestriverforums.com/forums/f96/dining-slide-out-screams-when-it-is-going-out-and-coming-in-have-lubed-both-teeth-arm-116340.html)
mikejm 08-21-2016 04:06 PM
Columbus by Palomino 320 RS
Bama Rambler 08-22-2016 10:01 AM
Did you lube the sliding rail all over? If not try lubing the entire sliding mechanism.
You may need to run it in and out a few times, lubing it each time before you get it to stop yelling at you.
5picker 08-22-2016 10:05 AM
Yes, you will need to lube more than just the teeth.
Also use a good DRY lube. Do not use spray grease.
mikejm 08-22-2016 01:14 PM
Did not lube entire arms, just the teeth. Will try lubing entire arms.
mikejm
campingguy 08-24-2016 08:23 PM
Is it a Schwintek? If so, go to their website. They have troubleshooting instructions and lubrication procedures, complete with videos.
mikejm 08-25-2016 12:08 AM
camping guy I don't know what a Schwintek is. mikejm
campingguy 09-06-2016 02:20 AM
This is a schwintek:
http://www.amlrv.com/site/wp-content...echanism-2.jpg
