-   Cherokee (http://www.forestriverforums.com/forums/f24/)
-   -   Slide top seal? (http://www.forestriverforums.com/forums/f24/slide-top-seal-119627.html)
Tyler_13 10-05-2016 07:12 PM
Slide top seal?
2 Attachment(s)
Attachment 122230
Attachment 122231
Is the top of the slide seal suppose to look like the second picture? 2/3rds of the slide has a good seal with an edge that kind of comes up and holds water out. But on the right side of the slide the top seal is very angled down and doesn't have the curved top part. The slide leaks a small bit of water on the right side next to the bunks and we can't find where it's coming from. Could this be the problem?
Twistedpairs 02-06-2017 11:06 PM
I can't say it enough, take it in! We ended up taking ours in 4 (or was it 5?) times to get ours fixed. We are now out of warranty and since everything is frozen still don't know 100% if it's fixed. We have had the slide front seal replaced 3 times, the rear once and the top two or 3 times. They finally solved it by putting two seals along the top and upgrading our side seals to the "updated" seals that are shorter and don't get caught in the gear strip. We'll find out this spring if it worked!
