-   -   Water heater (http://www.forestriverforums.com/forums/f96/water-heater-128070.html)
Puma 2015 03-05-2017 10:44 AM
Water heater
I have a 2015 puma 31', I have a propane switch inside but not an electric one. What is the switch for that is in the lower left of the water heater outside
larrys2112 03-05-2017 10:48 AM
That is the electric switch.
Puma 2015 03-05-2017 10:50 AM
Why didn't they put it inside
wmtire 03-05-2017 11:00 AM
This link may help explain the operation of.
http://www.forestriverforums.com/for...tml#post327988
Suburban does make a model with the electric switch inside. However, if you inadvertently EVER turn it on without water in the tank, then you get to replace your now burned up electric heating element.
Having the electric switch on the tank itself, let's you also verify there is water in the tank BEFORE turning on the electric element.
It's explained in the link.
Puma 2015 03-05-2017 11:11 AM
Thank you,very helpful
