-   -   TV Mount in SV264RKS (http://www.forestriverforums.com/forums/f35/tv-mount-in-sv264rks-138015.html)
bob213 06-30-2017 12:19 PM
Our tv pulls down from behind the upper cabinets above the dinette. Does anyone know what kind of mount this is or how to release the tv from it?
bob213 07-01-2017 12:22 PM
Come on. I can't be the only one with this mount!
schrederman 07-01-2017 10:13 PM
I had a '12 SV 264 which is the same floor plan. There's a tapered fixture that the TV is screwed to. In the middle at the top is a clip to keep it from bouncing up and off. I can't remember if you have to push the clip toward or away from the TV... but with the TV pulled all the way down, you can release the clip and lift it off... To put it back on just position it correctly and let it drop onto the taper and the clip will engage. My TT came with an outside TV mount that was the same as the taper inside. I could move it between locations, but I never did. I just bought another small TV and another tapered mount.
Enjoy!
bob213 07-02-2017 12:34 AM
Thanks for responding.
My TV slides down from behind the upper cabinets (hidden when not in use) and slides on what looks like two drawer slides. Are you saying that the TV is attached with the bracket in the following picture? I have this bracket in the bedroom but couldn't see it on the dinette TV. I'll have to look again. Thank you again!
schrederman 07-04-2017 03:37 PM
Yes, that's made onto the sliding mount. Enjoy!
