-   -   Check Fuel Cap (http://www.forestriverforums.com/forums/f232/check-fuel-cap-140632.html)
FireSurf 07-29-2017 09:54 AM
Check Fuel Cap
I had the check fuel cap light come on. I screwed it back on and light is still on. Anyway to clear this? Anyone have this problem?
KY25DS 07-29-2017 02:50 PM
Try cleaning the rubber seal with a paper towel and also around the neck of the gas fill tube. May have a big of dirt or debris.
TheGerman 07-29-2017 03:03 PM
It also does not turn off immediately, it may take a few drive cycles.
StephanFR3 07-29-2017 03:31 PM
Attachment 146470 Yes with one of these.
M109Rrider 07-29-2017 04:15 PM
https://www.amazon.com/dp/B005NLQAHS..._vQpFzbVYJQT0M
I have one similar to this and use the torque app on my phone
drivmsafe 07-30-2017 02:29 PM
You may also want to have your gas cap tested to be sure it's venting properly. Most shops or part store can do this for you.
StephanFR3 07-30-2017 02:43 PM
If it is your cap. My past experience is if you buy a new one, the factory ones are alot better than the cheaper aftermarket ones. Buy it online through usually alot cheaper than the dealer, but you must do your research and know your part numbers.
