-   -   TV/Antenna Questions (http://www.forestriverforums.com/forums/f96/tv-antenna-questions-145031.html)
mrgem 09-22-2017 07:45 PM
Just got back from our first "real" camping trip in our 2017 FB180 Palomini-- 2 nights at 10,000 ft above sea level with no hookups or power.
Learned a ton about what performs well and what needs improvement on this trailer as well as what falls apart on bumpy roads. We'll save that for a future discussion, though.
What I need to know today is how to get a TV installed and how to get the most performance out of the factoy-supplied antenna. Unlike most of the bigger Palomino models, mine came with a fixed position TV antenna. It looks like what is called a "Bat Wing" design -- but doesn't appear to raise or lower - or even turn. There is nothing in the owner's manual about this particular antenna (although there are comments about an adjustable model) -- so I'm wondering if it is worth even trying to use it. Should I just invest in a larger omnidirectional model?
Also, just bought a little 19-inch flat screen and was wondering how I install the bracket I bought with it. There is a power outlet as well as a coax outlet on the bulkhead wall above the dinette. On the panelling directly below the 2 outlets, there is a sticker that says "TV backer." Is this a reinforced plate between the studs to which I can screw the TV mount?
The instructions that came with the mount says "mount on sheetrock only" and that I should mount it on a wall stud. If this "Backer" is substantial enough, though, I see no reason why I shouldn't mount the bracket on it -- rather than a wall stud. The TV weighs less than 10lbs.
Your thoughts?
TIA
SeaDog 09-22-2017 07:50 PM
The backer is for mounting the TV and should hold it fine don't use long screws nothing bigger then about 1.5 inches. Not sure about your antenna other then it is more then likely what they call an omni directional until. I have not heard good things about fixed units.
mrgem 09-22-2017 08:03 PM
I appreciate the input, it's exactly what I wanted to know.
I suspect you are right about it being "Omni Directional." It looks a lot like this one:
https://jet.com/product/detail/f2ae8...a-b5459fdf736e
RSchleder 09-22-2017 08:15 PM
I've owned many RV's with about every type of OTA antenna and in my humble opinion, you just can't beat the crankup Winegard unit. It rotates to "face" the available stations and works even better with their inexpensive WINGMAN option installed.
Asrabbit 09-22-2017 08:27 PM
My guess is what you have is a CA-2500. I have the same thing and and I am replacing it tomorrow with a King Jack. From everything I have heard, those antennas are not very good. I have never gotten mine to work well at all.
mrgem 09-23-2017 09:30 AM
And Thanks To All...
I've gotten a number of good suggestions. Thank you all.
Sounds like I have a low-dollar omni-directional antenna that needs to be replaced with something more effective. I guess what I need to do is to select either a directional antenna or another (but higher quality) omni-directional antenna.
I am concerned about the need to add or modify a roof penetration -- as that invites leaks.
SeaDog 09-23-2017 10:07 AM
If you take your time and follow the directions along with good common sense your antenna installation will not leak. I have the old tried and true wineguard batwing on my new TT with a wingman installed and get excellent reception.
Asrabbit 09-23-2017 01:21 PM
I installed a King Jack OA8500 this morning. I will see how well it really works once I head out on my next trip.
mrgem 09-23-2017 05:38 PM
King Jack
Let us know how well it works.
Asrabbit 10-01-2017 05:23 PM
Just tested it at Lake Bob Sandlin State Park. Picked up 7 channels. 1 was not very goog but the rest were crystal clear. The antenna that came with the camper might pull in a channel but it would freeze up and it couldn't be watched. So I would say the King Jack gets 5 stars.
keith_h 10-06-2017 09:58 PM
I know this is kind of late. In my trailer the TV mounts as part of the cabinet frame but in other places where the manufacturer mounted items to the luan they used 1/2 OSB as a backer. You should be able to use a stud finder to locate the edges of the TV backer to be sure the mount is in correct area.
