-   -   Back-up camera (http://www.forestriverforums.com/forums/f35/back-up-camera-148817.html)
yakmeat123 11-22-2017 03:36 PM
Back-up camera
The new Surveyor we will be receiving has the Backup camera prep. My understanding is that comes with a mounting bracket as well as the wiring to the power source. The dealer recommended a Furion unit to us. I am wondering if you have any recommendations as to other brands, the model of Furion , or any other tips as to how easy this will be. I have a 2016 Tundra Platinum if that helps in the assessment of my quandary.
Steve
CurtPutnam 11-22-2017 04:00 PM
Just make sure you get the observation camera. Furrion distinguishes between backup (only) and observation (full time.)
marinerjoe 11-23-2017 04:48 AM
I bought the Furrion Observation camera, installed it in a matter of minutes, and absolutely love it. It gets power from the marker lights, so make sure they are on (I drive with headlights on even during the day) and you’re good.
rjshiflet 11-23-2017 07:25 AM
Like MarinerJoe - I've got the Furrion observation camera. It was very easy installation and works like a charm. The only time I've ever turned it off during a drive was at night when I was in torrential rain. It was useless then and very distracting. But, that's going to happen with any camera.
We are 41 feet long and it works great for us.
dbledan 11-23-2017 04:26 PM
Have The observation camera. I would have liked to be able to use with a video out but they don't have one available that I have found.
I ended up putting a suction cup in the mount and stick it on the rear view mirror so I am just checking the normal places...less sway this way for me.
I tried a cheaper camera and went back to the furrion because it is much more reliable.
benchmarks 11-23-2017 04:41 PM
When and what would I use the cmos cameras for?
SailorSam20500 11-23-2017 06:31 PM
Furrion Observation camera is good for knowing when you can pull back into a lane after passing. You can easily tell if you are ahead of the people and if someone is tail-gating. I use my side mirrors to see way back, wide angle of the camera make cars more than 200 feet back almost disappear. Happy with the camera. I use a couple of rubber bands to mount the monitor on my rear-view mirror.
bgoakey 02-10-2018 08:40 AM
I have a 2018 243RBS and have been going to put on an observation camera as well. What model did you end up getting and how was the installation?
KFX450RXC 02-10-2018 09:17 AM
Same here. Not 100% perfect or 100% clear but still a good camera and easy to install.
Okmechanic 02-10-2018 10:07 AM
I just installed the Furrion FOS48 observation camera as my new trailer was pre-wired and installation took about 5 minutes or less. Dealer said they would install for $500. I caught it on amazon for $296. I have been watching on amazon but it was over $350. I saw the price drop and rise over $50 in a few hours and guess I just caught it at the right time. I bought one the next day for a work project and paid the $350. I played around with the camera at work testing the range. Furrion claims a 100 foot range but I still had a good signal at close to 100 yards. I have seen posts about loss of picture claiming poor signal quality but I would bet the have a loss of power supply from loose wires on camera. Adjusting the contrast and brightness make a big difference in picture quality. I have not pulled my trailer yet with the camera but the work camera has been very dependable so far.
DustyRoads 02-11-2018 06:58 PM
I got a great deal on a Garmin Backup Camera to work with my GPS. If it doesn't work I haven't spent a bundle on it. I have know I might have to buy the extension cable. Plus it has mixed reviews. Since trailer is covered I will be another month or two before I get to play with the new camera.
I am wondering if it comes on with lights or only when in reverse. I have read some people, as above, with light and a few only when in reverse. I will use my tester to determine.
Good luck to you.
dbledan 02-11-2018 11:56 PM
Good luck to you.
Just a thought if it works when only reverse is on.
My trailer has no reverse lights. If yours does not either you could wire your reverse to the running lights to make it work when the running lights are on via the junction box for the 7-way.
If you have reverse lights then this would not be a good idea.
DustyRoads 02-14-2018 11:48 AM
This won't overload the lights if both backup and tail lights are on? I will explore it in the spring thanks
