-   -   3011 ds slide not working (http://www.forestriverforums.com/forums/f15/3011-ds-slide-not-working-155231.html)
Sherol 03-17-2018 11:48 AM
The living room slide will not work. The bedroom slide is working fine. I checked the fuses and they are OK. Any suggestions. This is a 2018 Forester 3011 DS and uses the wireless Lippert system.
Joshua Cavitt 03-19-2018 04:00 PM
Make sure there is power going to the slide motor. If there isn't you can always bring it in manually. To manually bring in the slide look in the storage compartment underneath the slide.
Sherol 03-27-2018 12:08 PM
It was a burned 20 amp fuse in a compartment under the closet in the bedroom. Replaced it and slide is now working fine.
77rednecktruck 03-30-2018 09:50 AM
Good find!
Thanks for posting the fix. :)
MikeRP 03-30-2018 07:19 PM
Could you take a picture of that location and post it?
Sherol 04-04-2018 05:34 PM
4 Attachment(s)
Here is the area where I found the burned out 20 amp fuse for the main slide in our 2018 3011ds . Some of the pictures have turned or are completely upside down and I'm not sure how to fix them so I hope you can stand on your head!
Duckogram 04-04-2018 09:03 PM
You have to edit the pics b4 u post em. Crop a hair off and rotate as desired. If they are right side up they will post that way after edit.
