-   XLR (http://www.forestriverforums.com/forums/f206/)
-   -   Black water tank flush (http://www.forestriverforums.com/forums/f206/black-water-tank-flush-15867.html)
Steve38 08-22-2011 08:23 PM
4 Attachment(s)
The idea of pulling a garden hose into the bathroom to flush the tank, not too appealing to me. For about $15 i bought this handy device. I did not the buy the one that claims to turn. Most reviews were negative. This one just sprays the inside of the tank from static holes drilled in the nozzle. Very easy install.
I added a few feet of garden hose to gain access. (the tank is behind the axle)
Herk7769 08-22-2011 09:36 PM
Make sure you always use a backflow preventer on the hose end.
You should also install an anti-siphon valve to prevent black water from entering the flush hose and siphoning it out the inlet while you drive.
Fire Instructor 08-22-2011 09:48 PM
They normally get sold with the anti-siphon with the kit. Make sure that you use it, otherwise, although a long-shot, you could really contaminate a water system badly.
Also, don't forget the winterize that line when you put your unit away for the winter. The water in the hose and sprayer will freeze and damage it. I just blow it out with compressed air.
Steve38 08-22-2011 10:05 PM
The anti siphon is built in. I store my trailer inside a heated building. I winterize in case the power fails. But thanks for the tip.
GaryRudolph 03-30-2012 11:17 PM
Steve, like the idea on the flush. Better than letting the kids fill up the black water by running the fresh water. What did you do to mount the hose on the outside?
Steve38 03-31-2012 07:36 AM
Yes, i ran a few feet of hose for easy access
GaryRudolph 03-31-2012 12:18 PM
You just hang it underneath or drill the side?
Steve38 03-31-2012 01:04 PM
I did the side so water will spray the length of the tank. It works well. I have a clear extension on the drain before the macerator pump. I was surprised at the amount debris it washes out.
Steve38 03-31-2012 01:09 PM
2 Attachment(s)
I can post more pics if it will help.
GASPEDDLER 03-31-2012 01:37 PM
Steve, did you mount the loose end of the hose to the side of your trailer for easy hookup to a fresh water source? Or is the hose simply tucked up/coiled up underneath your TT? Where did you purchase the kit?
