-   Dynamax (http://www.forestriverforums.com/forums/f240/)
-   -   led dimmer (s) needed (http://www.forestriverforums.com/forums/f240/led-dimmer-s-needed-160307.html)
esp 05-21-2018 02:48 AM
I just got a 2018 Isata 3 and the led's are way too bright. I took off the bezal and lens to check the bulb, but it is integrated into a small module. I had found 12v led dimmers and am not sure if they will work with this lighting setup. I would prefer dimming to lens darkening. Any ideas?
Magnatudes 05-21-2018 10:06 PM
Double Dimmer
Single Dimmer
:D :signhavefun:
Loefflerh 05-22-2018 08:58 AM
That was my solution for the lights over the dinette - same problem, uncomfortable bright. The little module is hidden in the wall behind the original switch and works perfect!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
esp 05-25-2018 11:59 PM
Originally Posted by Magnatudes (Post 1816511)
Double Dimmer
Single Dimmer
:D :signhavefun:
I ordered one and although it is smaller, I could make do, but mine has a white wire in and out vs, 4 wires for these switches.
Charles in TN 06-21-2018 04:41 PM
The problem I ran into is that the 4wire dimmers require you to find the negative from the LED string and disconnect it from the frame and run it back to the dimmer. I have no idea how that would be accomplished on my RV since I haven't found a wiring diagram for it. Now I have 2 of these devices and no way to use them.
