-   -   Roof Warranty Question (http://www.forestriverforums.com/forums/f227/roof-warranty-question-171992.html)
Mrs.Shockley 10-09-2018 02:34 PM
This may not be the right forum...
We recently ran across a 2017 Wolf Pup 16FQ for just over $9,000. We're thinking of getting a weekender-sized TT and this pretty much fits the bill, but we're brand new and not 100% sure what we're getting into. I read on line that the warranty on the roof is 12 years (as opposed to the structure of the trailer itself, which is 12 months). I'm not sure exactly what that means. If we buy this trailer and the roof springs a leak, is that covered? Does that mean they'll repair/replace it? Obviously, buying used we don't know how well the prior owners have kept the roof. All we can see at the moment is that it's a bit dirty, but we haven't been able to check caulking, etc.
Can anyone shed light on the warranty on a TT roof?
bikendan 10-09-2018 02:50 PM
The roof warranty is ONLY for original and not transferable.
Reverse_snowbird 10-09-2018 02:51 PM
You're going to have to check with the manufacturer of that roof. Generally warranties cover the original owner only, but don't quote me.
You need to check the caulking before you buy that rig. Also look on both the outside and inside for water damage, things sagging, etc. Also, use your nose. We've looked at a lot of rigs and the first thing I noticed was the smell of mildew. If it has the smell of a strong deodorizer, be wary.
Just as important as the roof, check to make certain everything works inside. If the a/c, furnace, water heater, water pump don't work, those can be expensive to repair.
