-   Coachmen (http://www.forestriverforums.com/forums/f214/)
-   -   2013 Clipper Tub/Shower water shutoff? (http://www.forestriverforums.com/forums/f214/2013-clipper-tub-shower-water-shutoff-176427.html)
K4RGD 12-31-2018 08:28 AM
We’ve noticed a bit of moisture pooling below the tub spigot in our 2013 Clipper whenever we hook up the city water connection... but we never use the tub or shower. I can only assume the water supply to the faucet is leaking... albeit very little. There wouldn’t happen to be a convenient shut-off valve hiding that would just kill water flow to the shower?
Planning to take it in for service to repair whatever leak is happening anyway...
Thanks in advance.
Attachment 193721
Toddupton 12-31-2018 08:31 AM
Just pull the four screws holding the faucet on and pull it out to check. Could just be a loose fitting on the valve. 2 minutes to check it could save you from having to take it in for something so easy to check first
cavie 12-31-2018 08:43 AM
X'2
K4RGD 12-31-2018 12:12 PM
Now being told the water pools after using the kitchen sink. Will check the hoses under the cabinet. Any other thoughts?
5picker 12-31-2018 12:35 PM
If you are saying the water pools at the shower after using the kitchen sink... not uncommon for a leaky fitting.
As the water supply pressure raises and lowers from use at another faucet or spigot, the leaking fitting can drip more/less from the fluctuating pressure.
levic900rr 01-31-2019 12:40 PM
Are you using a water pressure regulator? If not maybe you're putting too much pressure on the system.
K4RGD 01-31-2019 05:45 PM
Yeah, we always use a regulator. We started using one of those with our old popup and (thankfully) had the good sense to continue using it with our Clipper. I just wish there was a full shutoff valve for the shower. We never use it, never plan to. Keeping the water out of it would make winterizing easier too.
Indy500 01-31-2019 07:40 PM
Sounds like a summer job, track the water lines back and cap them off.
