-   -   Flagstaff 2019 26 RBWS (http://www.forestriverforums.com/forums/f33/flagstaff-2019-26-rbws-180673.html)
BillyBass 03-17-2019 06:16 PM
Can anybody give me any pointers on it.Picking it up on Tues the 19
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites 2018 11 nites
2015 16 nites
True North 03-17-2019 09:54 PM
Two things come to mind - use a good wdh. Shes a nose heavy beast with a tongue weight pushing 900-1000 lbs. Having said that, she towes beautifully. We also replaced/improved the screws securing the sliding door straps. We had one pull out and you dont want the door moving in transit.
Enjoy your 26 RBWS - its an amazing trailer!
Daves rv 03-18-2019 11:21 AM
We have the Rockwood version. We did replace the sofa with theater seats. If you don't need the sleeper sofa you may want to swap it before you pick it up. The sofa is not comfortable to watch tv for any length of time. As a bed it is pretty good.
Msgtret 03-18-2019 12:24 PM
We are taking ours on her first trip this coming weekend to Up the Creek Campground in Pigeon Forge. She is nose heavy as stated but tows great.
BillyBass 03-19-2019 07:26 PM
We pick it up today .can anyone tell me where the battery disconnect at
Msgtret 03-19-2019 07:35 PM
It’s located just forward of the battery box on the left side. Big red handle...
BillyBass 03-20-2019 04:44 AM
Thanks I found it
BillyBass 03-21-2019 04:55 AM
Originally Posted by BillyBass (Post 2050789)
Thanks I found it
Let me know how it goes ..good luck did you get two tv s I was going to add the one in the bedroom any suggestions
Msgtret 03-21-2019 05:41 AM
Only have one TV but are thinking about one for the bedroom. We have the electric stabilizers, Stainless Steel appliance package and larger A/C.
BillyBass 04-14-2019 06:41 PM
We took out the new camper this weekend for the first time and we had a great time.We had a 21ft before upgraded to a 26 ft rbws so much more room cant wait to go back out in May
Msgtret 04-14-2019 07:01 PM
We really enjoyed our first trip. About 570 miles one way and had zero problems. The fun part was heading home, I-75 was shut down going north at Caryville. Had to take the old 25W to Jellico. Not the easiest road to tow a camper on.
GrayghostUSA 04-16-2019 03:30 PM
We got our 2019 Flagstaff RBWS almost a year ago. We really like it and I have made a ton of improvement/changes. Turned out our dealer knew squat about the Equalizer hitches and set ours up wrong. We took it back to them and they still screwed it up. Finally took it to a place here in Marietta and they did it right. There is so much tension on the bars that we added Air Lifts to make that easier. We found out that when traveling, 15 psi is perfect. Don't take anybody's word for it. Go to the scales. Get your truck weight loaded with people and stuff and a full tank of gas without the trailer. Then reweigh with your loaded trailer. Visually the trailer should be setting level. If it is nose down the trailer front axle will be heavy and the rear light. Oh yea, at ~500 miles we got rid of the China Bombs and as a added advantage could tell an improvement in towing.
BillyBass 04-16-2019 08:37 PM
What is your gvwr on the trailer and what is your truck gvwr.When I pull mind i had a 3 mile hill and it made it
GrayghostUSA 04-17-2019 08:07 PM
The GVWR for my truck is 7050. The GVWR for the trailer is 7864. The max tow capacity of the truck is 11800.
Unless you are towing with a 2017 Ford F-150 Supercab, 145" wheelbase, 3.5L EcoBoost, 3.55 Rear Axle, 4WD, 10 speed trans, HD tow package, etc., etc..... These numbers are useless to you.
I got to know the CAT Scale real good to get mine fine tuned.
