-   Slide Outs (http://www.forestriverforums.com/forums/f229/)
-   -   2014 220RBS slide no power (http://www.forestriverforums.com/forums/f229/2014-220rbs-slide-no-power-184321.html)
grosjo 05-05-2019 09:01 PM
I retracted le slide in no problem last fall.
Tried to extrend today and not even a click.
No leds, neither red or green on the Lippert 13398-c2.
Tried the over ride botton and nothing flashed.
took the 13398-c2 off the wall, opended it ans saw very little of corrosion
on a component on lower part of circuit board….
Board was install about floor height,upside down..
Could this be the issue?Should I get a new controller right away ?
Is there a way to manually extend the slide out in the mean time ?
Thanks for the help.
Grosjo from Quebec
grosjo 05-06-2019 06:52 PM
I ended up wiring both motor directly to battery and got the slide out.Will do same thing this fall for retracting.
Jo
