Quick Stop - Jacks Down?
We have a 2012 Flagstaff T12 that we will be taking cross country this year. As part of our journey we will have some quick nights were we just stop to sleep and get right back on the road. My question is - if the camper is hooked to the SUV do we have to put down the stabilizing jacks for those quick stop nights?
if i'm still hooked to the TV, i never put down the stab jacks.
no need
it will be more rocky but you will not be doing much walking in your rig anyway just pulling over for a little sleep have a great time Mountainman |
I would do whatever makes you comfortable. As for myself, I lower them for over night stops just to make the camper a little more stable when moving around inside. You may want to hook up to your TV and try it with the stabs up and then down and then decide. That's what I did.
Good Luck. |
I don't mess with the jacks for a quick overnite stop.
I put them down and chock the wheels I don't care for all the movement. I would try it with and without them down and decide for yourself.
I put the stabilizers down. I use a cordless drill, so it only takes a minute to do.
Whichever way you decide, I'd recommend unconnecting the wiring plug between the camper and the tow vehicle to keep their batteries separate overnight. This was recommended to me by the dealer, perhaps it's not necessary but I've been doing that (and leaving the jacks up).
Many new tow vehicles have an isolation switch....when the motor is turned off, then the hot wire to the trailer is disconnected. If a vehicle has that, then I don't see where leaving the tow vehicle and trailer hooked up would be a problem. If a vehicle doesn't have that, then there could be a problem with drawing down the TV battery. But there again, that would effectively give you 2 batteries instead of just 1.....I think.
My 2006 F150 has the isolation switch. |
I was told by the service department to unplug the wiring plug to prevent over charging.
I'm with everyone else on this for a quick overnight stop - if you need the jacks then lower them otherwise just leave them up. Either way I would still use chocks. |
