-   Salem (http://www.forestriverforums.com/forums/f26/)
-   -   '07 25BHBS Bunk Slide Adjustment?? (http://www.forestriverforums.com/forums/f26/07-25bhbs-bunk-slide-adjustment-20959.html)
stack_climber 03-22-2012 11:57 PM
Need help please! We recently bought a used 2007 25BHBS (Rear bunk slide). The living area slide has adjustments underneath however, the bunk slide doesn't. The top rear of the bunk isn't going out all the way, enough so that I can see sunlight reflected onto the ceiling inside the camper. The other tree corners are out fully against the slide gasket / seal. Do I have to rip up the bottom bunk to be able to get to any adjustments or, is there any adjustment at all? It almost seems to me that the end closest the front of ther trailer is getting full out before the rear end of the bunk. Any help would be greatly apreciated. Thanks!
stack_climber 03-27-2012 07:54 PM
Really.....nothing.....not even from a Salem or Forest River rep?? Ok then.
