-   -   "Official" word one tire pressure? (http://www.forestriverforums.com/forums/f210/official-word-one-tire-pressure-23563.html)
dapersico 05-21-2012 07:40 PM
Is there any official word on what I should set the tire pressure to on my Tracer 2670BHS with ST205/75R14/C tires?
I've looked through all the manuals and can't find anything. I've also read these forums and find conflicting recommendations.
Dwayne
lbrjet 05-21-2012 07:51 PM
Max sidewall pressure, probably 50 psi, filled cold first thing in the morning before the sun hits them. Then only check them first thing in the morning as well.
Dave_Monica 05-21-2012 07:53 PM
Set the cold inflation pressure to the maximum pressure noted on the sidewall of the tire...yours should show a maximum pressure of 50 psi.
Dave
shabbona north 05-21-2012 07:54 PM
The correct pressure should be on the trailer, mines on a plaque up on the A frame
dapersico 05-21-2012 08:11 PM
Wow! Thanks for the quick replies. My tire pressures were actually quite low I kicked them up to 45psi but I think the max was 60psi. I'll kick them all the way up and see how things go. Hoprefully my gas mileage will improve a little bit.
Dwayne
