-   Cherokee (http://www.forestriverforums.com/forums/f24/)
-   -   Cherokee 29 BHS Winterizing (http://www.forestriverforums.com/forums/f24/cherokee-29-bhs-winterizing-2890.html)
camphappy 10-21-2008 08:34 PM
Just winterize my camper for the first time. Do I have to flush the Santi-flush system with anti-freeze? If so how do you do it?
Bama Rambler 10-22-2008 07:40 AM
While I don't have a San-t-flush, I'd have to say, yes, you need to at the very least blow it out with air. You could always take a piece of hose and a small tipped funnel and pour antifreeze into it.
Since it has a back flow valve that may require a small amount of pressure to open you could adapt a plastic bottle to the hose instead of the funnel and use it to force the antifreeze into the san-t-flush tubing.
steveqvs 10-22-2008 09:07 AM
Last year I just pressed the little spring backflow with my finger and added some RV antifreeze. This was after I had emptied and rinsed the tank. Seemed to work just fine.
