-   -   sagging floor (http://www.forestriverforums.com/forums/f33/sagging-floor-29420.html)
johnymoto 09-17-2012 06:51 PM
sagging floor
sagging floor buy the heat vents. is this a problem with the supports under the floor of a 2007 flagstaff 831bhss. and there close by the door.and no water leaks ever around their:crying:.
kfp673 09-17-2012 08:52 PM
I have 2006 same model and the floor is soft in many places but around the vents are indeed very soft.
johnymoto 09-18-2012 12:38 AM
is there anything i can do about it. is there a support that has fallen down.
Gatekeeper 09-20-2012 07:14 PM
install a hardwood floor over the old floor ... solves the probelm for ever.
kfp673 10-28-2012 10:12 AM
That's not a bad idea but how would you do this and still allow enough room for the slides to come in and out?
That sounds like a great idea but how would you install a hardwood floor and stil allow room for the slides to come in and out??
johnymoto 10-28-2012 11:21 AM
i checked it out at the wood floor place you have to get the thinnest wood floor to make it work it cant be anymore higher than the carpet. i believe its engineered wood .
donanddona 11-03-2012 02:41 PM
Talked with the factory rep at Forest River. Thge hardwood floor can be 3/8" in hieght. Although he did advise running the boards lengthwise to ensure support. If you remove a resister and peel back the alumimum tape you will see how the floor is constructed. Styrofoam sandwiched between two very very thin pannels... this compacts over time and does not provide proper support.....
johnymoto 11-03-2012 04:35 PM
and they wont stand behind their product. and if you have carpet close to it you have to use a rubber strip that clicks under the carpet and clicks to the wood floor and your right about the layout of the wood. and i was told you cant do it in the bathroom because of the flange under the toilet is this true.?
Cajun Po-Boy 11-03-2012 04:47 PM
Thank goodness for this forum and issues like this coming up in conversation because we almost bought a Flagstaff 5'ver with this type of floor until reading threads like this.
I stayed clear of this type of construction when shopping for our new fifth wheel knowing I'd have a fit when these issues surfaced.
Good luck!
