-   -   battery cables and such (http://www.forestriverforums.com/forums/f68/battery-cables-and-such-33410.html)
TURBS 01-18-2013 12:52 PM
If anyone is upgrading from one battery to two and need battery cables let me know as I can custom make them and I have a ton of "new" scraps of battery cable .
All ends would have copper lugs, soldered and heat shrunk to your specs.
Any length any size cable
Any lug size or postive/negative ends.
Turbs
TURBS 01-18-2013 12:54 PM
2 Attachment(s)
Attachment 23119
Attachment 23120
Better quality than what you'll get at a parts store .
Herk7769 01-18-2013 02:35 PM
Nice selection.
Herk :D
TURBS 01-18-2013 03:02 PM
Originally Posted by herk7769 (Post 293092)
Nice selection.
Herk :D
Second to none!
realebill 01-18-2013 05:17 PM
those assortments look familiar ! i used to sell them for an industrial supplier that i worked for before i retired !
TURBS 01-18-2013 05:27 PM
Sent pm
racedaymechanic 01-19-2013 04:45 PM
Turbs
Don't be offended but As a man who Builds and sells hundreds of Battery Cable sets a year, Ill help you alittle. 1. you stripped the wire back too far, It sould never be deeper than will go into the Terminal, 2. too much and not the right Heat Shrink. 3. Never Solder a Teminal on you Crimp it, I use a 20 ton Hydraulic Crimper but there are manual ones that work well
TURBS 01-19-2013 05:48 PM
No offense taken but I've been building battery cables for 20 years and soldered everyone.
The cable shown was not even soldered together I just heat shrinked over it for example.
Not sure where you heard never to solder a cable but if it werks for you to crimp that's ok to.
Not sure why they sell me soldering pellets and solder on ends either?
Turbs
racedaymechanic 01-19-2013 05:55 PM
Turbs
They sell the solder for people who dont have the proper crimp, the solder wicks up the wire and makes it brittle, If you have been doing this for 20 years you should have the proper tools
TURBS 01-22-2013 12:08 PM
It only wicks up if your doing it wrong or uneducated about soldering battery cables.
Turbs
