-   Reflection (http://www.forestriverforums.com/forums/f66/)
-   -   2000 Cummins 260hp oil Qty (http://www.forestriverforums.com/forums/f66/2000-cummins-260hp-oil-qty-33687.html)
AllenL1011 01-25-2013 05:51 PM
Could anyone tell me the Cummins 260hp engine oil capacity of my 2000 Reflection on a Spartan chassis? Conflicting information.
Thank you.
TURBS 01-25-2013 06:44 PM
Thank you.
Depending on which oil pan is on it.
Deep
Shallow or mid
Call your local Cummings dealer with serial number of the engine and they will tell you for sure.
Turbs
msham87 03-05-2013 10:26 PM
Did you ever get an answer to your question? I have a 2000 Reflection 327 with a 260hp 5.9 ltr Cummins diesel. Recent oil change with filter required 17 quarts of oil.
mshell56118 03-05-2013 10:49 PM
I work for Cummins. give me the serial number I will look it up
hin1075w 03-12-2013 11:49 AM
Just changed my oil and filter. Also 260 engine. My manual shows 19 qts. 14 qts took it to the full mark on dip stick. The other 5 qts must be in the lines and cooler. Just to be sure, I would call Cummings, give them the VIN no. and they can tell you for sure
