-   -   A few electrical question (http://www.forestriverforums.com/forums/f191/a-few-electrical-question-37498.html)
2012WhiteSolera 04-07-2013 10:45 PM
Sitting here reading up on proper battery charging methods getting ready for the upcoming season,rased a question or two. Where is the Inverter located on the 24S. Also, does anyone know if it is the "three stage" type inverter, allowing for a quicker coach battery charging sequence, when the generator or AC shore power is connected.
Slow_movin 04-08-2013 12:42 AM
If not mistaken, inverters are not standard on the 24S. The inverter changes dc current to ac current.
The converter changes (converts) ac current to dc. If this is what you are seeking, I will try to help. I had to replace my converter last year (2011 Solera). Open your big storage door on passenger side and remove the right panel. You can see the converter at the very top on the right. (Also you can see the 3 valves for turning the water off/on to your water heater.)
The converter has a wire that plugs into an ac outlet and two wires coming out the other end that are dc current. Yes..the converter on mine is the 3 stage. I think all this is correct since it's been a while since I was looking in there.
bikendan 04-08-2013 02:44 AM
you're getting the terms "inverter" and "converter" mixed up.
all RV's come with converters. as Slow Movin states, it converts AC shore power to DC power for the things that usually run on battery power.
an inverter does the opposite, converts 12v DC power to 110v AC power.
this is not factory-installed on most RV's, usually only large motorhomes. some
5th wheels have them as an option.
Taylorgso 04-08-2013 05:16 AM
FR is installing 12V TVs in the Solera, so the need for an inverter is minimized. You may need it for small appliances or chargers for a cellphone, etc., but you can get a small portable inverter that will do that job. A lot less costly... And no installation expense.
DebbieMH 04-08-2013 06:46 AM
When I'm hooked up to a 30 amp at a campground, my cell will charge. I'm fairly sure it would if the gen was running too. Why would you need an inverter?
Dave_Monica 04-08-2013 07:16 AM
When you don't have electrical hook-up and don't want to run a generator.
Dave
bclemens 04-08-2013 09:07 AM
To confirm, the converter is 3 stage.
Taylorgso 04-08-2013 10:34 AM
You could also charge it in the 12V receptacle in the cab. Nice to have an inverter to maybe power the satellite receiver & not be running the gen late @ night. If you ONLY camp with hook ups, you're right - you'll not need an inverter. But camping in parks without hook ups, running a gen late at night may be hazardous to your health (LOL).
2012WhiteSolera 04-08-2013 05:25 PM
Thanks. Meant converter. I had an inverter installed when purchasing to close the deal. And Dave your right , its handy when dry camping. Also, it allows me to just charge the electronics on the go with the existing 110 AC chargers that come with the electronic gizmos and not have cab clutter.
Thanks for all the input, its always nice to know there are like mined people who have constructive input. Also, thanks again BC, at FR ,for adding to this.
