-   -   Electrical Panel (http://www.forestriverforums.com/forums/f218/electrical-panel-37735.html)
garbonz 04-11-2013 03:18 PM
Electrical Panel
Here is a picture of my electrical panel. It's 50 amp and one side has
Converter
AC
Water heater
The other side has
AC2
Gen
GEN
Microwave.
Question is what the heck is GEN? I don't have a generator and I can't imagine what this circuit is for it does have a wire hooked up to it... And I don' know where it goes or what it does.
Any ideas?
ependydad 04-11-2013 03:24 PM
Captain Obvious: turn it off for a while and wait to see what doesn't work.
garbonz: Yes, but anyone with real ideas?
Captain Obvious: Look, there's Batman.
(points and runs away)
fonzie 04-11-2013 03:48 PM
Maybe this tread will answer your question......
http://www.forestriverforums.com/for...gen-15857.html
LaydBack 04-11-2013 04:32 PM
First one is GENeral receptacles. Second one isn't GEN, it's GFI, as in GFCI receptacles. General is basically all inside receptacles that aren't GFCI and typically this has your refrigerator as well. GFCI should be kitchen, bath, and outside receptacles.
garbonz 04-11-2013 07:40 PM
That actually makes sense AND I can check it. I find out tomorrow.
Woohoo
garbonz 04-13-2013 03:49 PM
Eureka, that's it. The GEN circuit is the outlets that are not in the kitchen or bath...
Good to know.
Sirsea 04-13-2013 04:17 PM
Only way to know for sure is to test each outlet and label them. We found the two outlets in the kitchen on either side of the stove are on the Gen breaker, however they are both GFI outlets. Both outlets on the kitchen island, the one in the bath room and the two outside outlets are on the GFI breaker.
garbonz 04-13-2013 05:34 PM
In my case it is the rear outlet in the living room, both TV's and the dressing area in the front of the bedroom that are on the GEN circuit.
