-   XLR (http://www.forestriverforums.com/forums/f206/)
-   -   27hfs xlr grill for use with the quick discnt. (http://www.forestriverforums.com/forums/f206/27hfs-xlr-grill-for-use-with-the-quick-discnt-37801.html)
melk-man 04-12-2013 09:09 PM
ok, so my xlr2hfs has a quick disconnect for the lp near the front door.. what are your suggestions for an outside grill and what hose would that take ? if you have one, what grill did you get ?
Dave_Monica 04-12-2013 11:24 PM
You can use any grill you want as long it doesn't have it's own propane regulator as propane line you're connecting to is already low pressure. Some grills have a removable regulator that would require some re-piping. The parts that you'd need to pipe it to a male quick connect should be readily available at any BBQ part supply outlet.
Dave
melk-man 04-13-2013 12:18 AM
thanks, i wondered about needing a regulator. but as you stated, it's already "regulated" from my tanks..
Yler4cy 04-14-2013 06:15 PM
What would it do if my grill has a regulator on it as well? Will it not supply enough propane to the grill?
GaryRudolph 04-14-2013 07:03 PM
I went with the cheaper Camco and used that with the RV side mount rails. It looks like that Camco isn't sold anymore, but the more expensive stainless steel one is. That came with support to run to the camper quick connect line as well had a regulator to run directly off the tank.
cmann785cc 06-18-2013 06:32 PM
Get a Coleman Road Trip and remove the regulator on the inlet contraption that comes with it and run a gas hose to the quick connect. Works like a charm. If you don't remove the Coleman regulator it won't get enough flow because it's double regulated.
Yler4cy 06-18-2013 10:02 PM
Awesome news cmann I already have a coleman roadtrip grill. Where did you get the hose to connect it to the camper?
ejkkj 06-18-2013 10:15 PM
I think is what you need, good luck.
Coleman High-Pressure Propane Hose and Adapter : Amazon.com : Sports & Outdoors
cmann785cc 06-19-2013 01:57 AM
It's been a while but I think Ace or True Value Hardware stores.
Yler4cy 06-19-2013 08:21 AM
ejkkj - I have one of those, but the connection on my camper looks like a high pressure air hose. Here is a pic of what it looks like:
http://img.tootoo.com/mytootoo/uploa...91c2519d3f.jpg
