GPS INFO FOR "FIREWORKS over the FALLS"
This is some information for those of you that use MAGELLAN GPS.
I found I could not enter the address supplied for "BISSELS HIDEAWAY RESORT" into my GPS. After a little searching, I found to enter the address this way, your Magellan will take the address. In the notice supplied by MR FROG himself (BOB) of RIDGEVILLE, ON, the GPS would not take the address. Try this address. 205 METLER ROAD FONTHILL, ON When you enter FONTHILL, ON, the GPS will auto convert over to PELHAM, ON. You can not enter PELHAM or RIDGEVILLE into a MAGELLAN and get the rest of the address only by entering FONTHILL, ON will let you enter the rest of the address. GOOD LUCK, WILL SEE YOU THERE FOR THE FOURTH> |
Directions - caution
2 Attachment(s)
We were in the area last weekend so we went up to see where this campground was and look it over. I used the GPS and it took us through some narrow winding roads. It also took us over one of the lift bridges that is under repair. We had no problem getting through but I was glad we were in our car and not the RV. You should follow the directions from their website which is:
From Niagara:
Here is what you are looking for!! |
