-   -   Help, Awning not working! (http://www.forestriverforums.com/forums/f228/help-awning-not-working-39230.html)
10x 05-05-2013 10:02 AM
I have a 2014 xlr27hfs toyhauler with a Dometic power awning. The awning stopped working. I hear clicking sound outside by the motor when I press the switch but it does not move. Checked the fuses OK. Is there something I should check before I take it back for service? It is 80 mile trip to the dealer. Thanks:crying:
OldCoot 05-05-2013 10:06 AM
Check that it is not bound up. Have someone intermittently hit the switch while you pull on the arms. Also check that the battery is full charged.
camper1999 05-05-2013 10:10 AM
Is your battery good, I am assuming it is since it is a newer trailer. If it is clicking sounds like it is getting power. Unless someone else has any other ideas sounds like a warranty item.
10x 05-05-2013 10:10 AM
I have plugged it plugged in to shore power. I will try having someone pull on it
Picked it up yesterday from dealer. I went to deploy the awning to install the support poles you sent and all I hear is clicking. Worked fine before.
OldCoot 05-05-2013 10:13 AM
Did you get your poles?
camper1999 05-05-2013 10:21 AM
Even if you have it plugged into shore power if your battery is no good it will not work. But could be a binding issue
rattleNsmoke 05-05-2013 10:26 AM
Not sure, but when you hear a 'clicking' there's usually a relay involved.
10x 05-05-2013 10:29 AM
Yes I got them, I was going to install them when this happened
10x 05-05-2013 10:32 AM
I just tried to nudge on it while wife pressed switch. Still have the clicking noise. I am able to unroll and roll it by turning the roller by hand, Should I be able to do this. I thought there is spring tension to hold it back.
garbonz 05-05-2013 10:33 AM
Bound up or warranty. Maybe the fabric has become miss aligned. Check to see if the fabric is centered on the track both at the wall and at the arm,
